Old 07-20-2004, 06:34 AM   #1
sxpert
Opus 90w problem
Just bought an opus 90w power supply and have an issue
here's a description of the test setup :
I use a regular 9 EUR PC power supply designed for a P4 system to power the opus (via the 4 pin connector) with 12v (the supply is rated for 13 amps of 12v)
the computer is currently composed of an EPIA M 10000 and a seagate laptop HDD (ST94811A 40G http://seagate.com/cda/products/disc...81,594,00.html )
when I turn the power on, the opus starts, but shuts down about 35 seconds later.
this does not occur when the HDD is powered from the regular supply while the EPIA is powered by the opus.
Any clues ?
I don't need no stinkin' startup-shutdown controller... That's what journalized filesystems are for...
NavSys, the ultimate navigation app
http://www.navsys.org/
sxpert is offline   Reply With Quote
Old 07-20-2004, 06:43 AM   #2
dominic is on a distinguished road
i tried running my opus 90w off an old crappy psu, as you are, and it shut down after about 30 seconds, but it works fine im my car.
i never tried connecting the hdd to the mains psu......
i just put it down to the crap psu i was using, and assumed the 12v rail couldnt supply enough power, then when the backup caps on the opus ran out, the opus shut down....
dominic is offline   Reply With Quote
Old 07-20-2004, 07:06 AM   #3
fly_dutchie's Avatar
fly_dutchie is on a distinguished road
Any clues ?
The Opus is not ment to be connected to a PSU. It needs continious 12v AND continious switched 12V to keep it on. If you turn the switched 12v off, the Opus will power down within the set time-out period. So momentary switching won't work, because it wouldn't know when to power down.
What 4 pins anyway, you mean 3 pins right?
Michael
"It does not understand, if it does not ride."
M10000, 512 Mb, 2,5" 40G, Slim DVD, Opus 90W, Xenarc 7", Leadtek 9532 GPS,
RoadRunner, MapMonkey, Pioneer HU, Pioneer 4 ch 400W, Kappa 6.5, Basslink X 200W
fly_dutchie is offline   Reply With Quote
Old 07-20-2004, 07:16 AM   #4
Raw Wave
Laidback's Avatar
Laidback is on a distinguished road
Michael
I think he means he used the 4 pin P4 connector on the ATX PSU to supply the 12v, you can just connect 12v to the constant and the switched connections and it *should* work but I still think it's power related.
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 07-20-2004, 07:17 AM   #5
sxpert
yes, I understood that, and connected both the opus RED and BLUE wires to the 12v rail
The regular PC power supply had (replaced with a 3 pin XLR) a 4 pins connector that is normally used to supply extra 12v for P4 based machines
any ideas on how to generate 12v for at-home testing (without ruining myself with a n electronics lab power supply) ?
Old 07-20-2004, 09:56 AM   #6
Don't test the Opus at home.
I just hooked up a crappy PSU's 20 pin to the board and connected the drives power cables. In this setup you can test acpi functions (hibernate, etc).
Then set pin switches on the Opus for a 20 minute shut down delay (tank circuit) and the powerdown option to hibernate/powerdown. (uses just a trickle of power)
The Opus should work out of the box, if it doesn't, at least you know you got the pc set-up right.
Michael
edit: I think there needs to be 12 volt present, before you apply the switched 12v, which needs to stay connected. You could try to put a switch on the switched 12v.
can i run all this on a 90w opus? DSM97RS Power Supplies 7 05-17-2004 04:27 PM
Strange problem powering xenarc from 90w Opus :( Brettster LCD/Display 3 05-11-2004 06:19 AM
Opus 90w, heat problem and the heatsink samc Power Supplies 1 04-19-2004 09:07 AM
wierd power problem (opus or m10000 prob) ob1 Power Supplies 4 03-31-2004 02:32 PM
Opus 90w Power Action EBoundEE Power Supplies 12 03-10-2004 10:11 PM
