07-23-2004, 03:29 PM
#1
Vehicle: BMW 320D Sport Touring
Help needed on switch install for Inverter
Hi all
i've got fed up of going to the bloody boot every time i wanna turn the computer on via the Inverter so decided to run a switch to the front of the car.
Basically the Inverter has a samll on/off switch built into it, i want to remove this switch and extend the + & - cables inside the car and install a nice new looking switch.
So, i bought myself a switch and the connectors are different, the old switch has a simple red and white however the new switch has 3 connectors, they are labled as follows: Earth, Supply and Load, can you please tell me first of all if i can use this, if so what 2 connectors do i use and also what is the 3rd for.
Thanks guys.
[SIZE=6]Join Date: Aug 2003
Vehicle: 2004 320d Sport Touring
HP-Epc, 512mb Ram, 250gb hd, Lilliput, GPS.[/size]
07-23-2004, 03:38 PM
#2
Vehicle: 1995/Chevy/Camaro
It is usually easier to leave the inverter switch switched to on all of the time, and then just switch the power that you supply to the inverter. Use a relay rated at the current you require.
As for your question, Earth is ground, supply is +12, load is the wire to inverter, thus most likely connection is to ground the earth, red from the inverter to the supply, white connected to the load (you should check with a voltmeter/test light the red and white wires. One of them will have a constant 12V on it all the time, the other won't. The one with 12V goes to supply, I'm guessing that it is the red wire.). You apparently have purchased a lighted switch, that is why there are those three connections.
2006 Chevy Colorado: VIA M10000 EDEN, 1 GB RAM, 80 GB 2.5" Seagate HDD, USB Slim Slot DVD/RW, Holux GPS, MobileVU 10.4" LCD (touch not working yet), VOOMPC Case (blue), 70W DC-DC supply.
07-23-2004, 03:54 PM
#3
Jackso,
Thanks for the quick reply, many thanks.
I decided not to run the master power cable to the front and use a relay for a fewreasons, here they are:
1, my main power cable is 4g and goes to a fused distibution box which then splits to a 8 g which geos directly to the inverter (its a BMW so all in the boot)
2, As the master cable is very thick would bo too much hassel to run it to the front.
3, i have no idea and no experiance with relays etc.
4, Just thought it would be a lot easier to open the inverter up, snip the existing swithc off and extend it.
You a corrent, the switch i bought has a light.
I have decided to bin the new swithc and just extend the red and white sires to the front and will use the existing inverter switch.
i'l also put in a little blade fuse in the red wire, any idea what fuse size i shoud use.?
Thanks mate
07-23-2004, 04:02 PM
#4
Vehicle: 02 WRX
Quote: Originally Posted by eazyrog
Jackso,
use a multimeter to determine the amperage draw and find a fuse as close to that as possible
rebuilding carpc... kinda..
07-23-2004, 04:05 PM
#5
fantomas,
Thanks but dont have one of those and also would not know how to use it.
My inverter simply runs a HP EPC, this mini pc comes with a 19V AC Adaptor (like the ones that come with Laptops)
Its a Piii, 60gb disk, cd, and a usb GPS Mouse.
any ideas
07-23-2004, 05:37 PM
#6
Raw Wave
Vehicle: '05 Shadow Mica Matrix XR
If you have a 300W inverter use a 30 Amp fuse if 350W use a 35Amp fuse.
/////Alpine PXA-H700
/////Alpine MRV-F345
Aura MR62 (F and R)
Sansa Clip
All wires by Knukonceptz.
My Current MP3s
IamDefiler.com
Still have tons of parts for sale!!! MB's, CPUs, Fans, etc. PM me and I will send a list.
07-23-2004, 05:49 PM
#7
Vehicle: 2000 Chevy Silverado Z71
I presume the switch is the light up variety? Use the 2 wires from the inverter on the supply and load pins (which lead goes to which pin doesn't matter). The earth lead goes to ground.
07-23-2004, 06:07 PM
#8
Vehicle: Toyota Echo 2003
There should be no need for a fuse in line with the switch if you are simply extending the current one that was in the inverter as it would only be using a very small amount of current as it would be switching the inverter on and off via a relay as well. The only sure way to tell how much current is running through the switch is to use a multimeter.
07-24-2004, 12:01 AM
#9
Raw Wave
Correct this would be for the + wire powering the inverter.
Aura MR62 (F and R)
Sansa Clip
My Current MP3s
IamDefiler.com
07-24-2004, 06:42 AM
#10
All done, thanks all, just extended the wires and also run a ground and installed the new switch with a light, looks great and now i dont have to open the boot, just put the system into Hibernate when i'm done and then switch it off using the new switch, when i turn it back on it powers up ready for use.
Thanks to all here once again.
| Thread Tools |
| Display Modes |
Linear Mode
