Old 08-02-2004, 02:46 AM   #16
MiniRX7's Avatar
Do you want to know how much a system makes a difference on your car?
I drive a 2003 6 speed manual Maxima with 255hp.
My system in my trunk only:
2 Infinity Perfect 12.1's in separate sealed MDF boxes
Kicker 550.3 class D amp
2 1/4 mile runs - SYSTEM IN!
1st run, 15.2 seconds
2nd run, 15.1 seconds
3 1/4 mile runs - After the above - SUBWOOFERS REMOVED!
1st run, 14.6
2nd run, 14.5
3rd run 14.5!!
Mind you my car is supposed to be in the low 14's but its because i had crap tires on.
My 2002 6 speed maxima, also posted 14.6 sec 1/4 times with no system.
My only explanation is given my car is FWD, the wegiht on the rear resulted in loss of traction.
2k3 Max SE 6spd
Temp setup:
7" indash screen/Xbox running XBMC
Carputer coming soon
My 2003 Maxima
MiniRX7 is offline   Reply With Quote
Old 10-13-2006, 03:34 PM   #17
madfish's Avatar
i've had no loss on my 528, the only problem I have is the lights dimming when the bass hits!!
madfish is offline   Reply With Quote
Old 10-13-2006, 05:37 PM   #18
There is a tech bulletin out on EMI interference causing problems with the ECU, and a fix for it (hardware swap which is EMI resistant). You have to pay for it out of your own pocket if this glitch is due to aftermarket equipment. Call up your dealer for specifics. Ofcourse this may not even be the problem (you have a lot of junk in the trunk from the sounds of it)
konfoo is offline   Reply With Quote
Enforcer's BMW E36 Carputer 1 Enforcer Show off your project 39 10-27-2007 09:08 AM
Opus and BMW (e46) captain_jim1 Power Supplies 24 01-20-2005 11:46 PM
BMW E46 headrests with 6.4 LCD screens r1r6rebuilder Classified Archive 1 07-04-2004 10:19 PM
BMW 2004 e46 Bezal / case for Lilliput. eazyrog Fabrication 4 06-03-2004 09:55 PM
For sale Xenarc 700TSV built for BMW E46 BMW Freak Classified Archive 0 05-21-2004 08:02 AM
