Old 09-03-2004, 08:12 AM   #1
lookinco is on a distinguished road
Cutting power to USB after computer has shutdown
My computer will keep supplying power to USB devices even when the computer itself is not on. If I use a self power USB HUB and take the 5V out from OPUS to power the hub, when I turn the ACC off and trigger the OPUS to turn off my computer, will it cut the power to the USB hub as well ?
With nothing connected to the USB port, does it still drain battery ?
Does the OPUS cut off power to the computer after a period of time after it trigger the computer to shutdown ? Or does it still supply power to the computer but just trigger it to shutdown ?
lookinco is offline   Reply With Quote
Old 09-03-2004, 08:41 PM   #2
KaiTech's Avatar
KaiTech is on a distinguished road
If you have a 150W it'll always power STDBY and USB devices on.
If you have a 90W all you do is take the jumper of and it won't.
I'll spout simplistic opinions for hours on end.
Ridicule anyone who disagrees with me,
and generally foster divisiveness,
cynicism and lower level of public dialog!
KaiTech is offline   Reply With Quote
Old 09-03-2004, 08:45 PM   #3
archimense's Avatar
archimense is on a distinguished road
Search...
OPUS 150's don't turn off standby power when they are off, which complies with the ATX power standard I'm told. So because of this your USB devices stay powered.
Look at this thread. The mod listed at post #78 works.
http://www.mp3car.com/vbulletin/power-supplies/24507-looking-creative-solution-usb-bus-still-powered-after-cpu-off.html
Jetta Install Photos
Audi S4 Worklog
01' Audi S4 Twin Turbo / 00' VW Jetta VR6.
archimense is offline   Reply With Quote
Old 09-04-2004, 06:22 PM   #4
For the 90watt OPUS. At what point does it switch off the 5V ? When the ACC trigger is off ? or wait after the preset shutoff time ?
So say my computer will shutdown after 20 min after the ACC trigger is off. At this point OPUS will trigger my computer to shutdown and cut off power to the 5v line ?
Kind of getting all confused again !
Old 09-04-2004, 08:06 PM   #5
GWRedDragon's Avatar
GWRedDragon is on a distinguished road
On the Opus 90w there's a jumper option to cut the 5v, and I believe it does so as soon as the PC is off.
GWRedDragon is offline   Reply With Quote
Old 09-05-2004, 06:30 AM   #6
geoff897 is on a distinguished road
Also you might want to try a USB hub they turn my lights off my usb mouse and keyboard
geoff897 is offline   Reply With Quote
Old 09-05-2004, 10:15 AM   #7
LanoX's Avatar
LanoX is on a distinguished road
1 question but what if u have 150 opsu and usb still stays on does it metter and will it damage the screen or drain the batter ?
tnx
[|||||-----] 95% complete
LanoX is offline   Reply With Quote
Old 09-05-2004, 11:48 AM   #8
Raw Wave
rando's Avatar
rando is on a distinguished road
tnx
No, it shouldn't damage your screen nor anything else in your system. It may drain or cause long term damage to your battery.
2004 4runner
rando is offline   Reply With Quote
Old 09-05-2004, 01:58 PM   #9
Do the inline ATX relay/diode mod in that thread that has already been referenced. It'll stop your system from draining your battery.
Old 09-05-2004, 11:36 PM   #10
Registered User
aoLhaTer's Avatar
aoLhaTer
do usb devices really use enough power to drain a battery?
i have my lilliput touchscreen and keyboard hooked up to a usb hub
would these devices drain?
i have a m10000 and a 150w opus
aoLhaTer is offline   Reply With Quote
Old 09-05-2004, 11:56 PM   #11
YES, if you don't start your car every day. The motherboard standby takes power too!
Old 09-05-2004, 11:58 PM   #12
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
I think that there is an option in the bios that disable power to USB.
0l33l is offline   Reply With Quote
Old 09-05-2004, 11:59 PM   #13
Registered User
aoLhaTer's Avatar
aoLhaTer
well ****
that may be why my car battery keeps dying....
im not really competent with making circuits and things; should i just sell my 150w and get a 90?
Old 09-06-2004, 12:06 AM   #14
Build the relay mod. It's not that hard, really.
Old 09-06-2004, 12:11 AM   #15
My Village Called
0l33l's Avatar
http://support.microsoft.com/?kbid=315664
No need to sell your 150w
If computer hangs, and constant current draw power issues Nic Power Supplies 0 06-14-2004 11:36 PM
power to USB stays on during hibernate ob1 Power Supplies 14 04-14-2004 10:53 PM
Will this power a computer? Vicked Power Supplies 2 11-11-2003 08:40 AM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 02:07 AM
portawattz 140 wont power up my computer.... TimW General Hardware Discussion 14 04-10-2000 09:14 PM
