The MP3car.com Store
Thread Tools Display Modes
Old 09-04-2004, 11:03 PM   #1
NiN^_^NiN's Avatar
Vehicle: 94 Ford Probe GT
My Photos: (2)
Morex 80w PSU not working?????
I'v just hooked up my morex 80w psu and it doesnt seem to work
When i hit the power button on the motherboard i heer a noise WINE but nothing happens
I hooked it up as the instructions says (instructions didnt say much)
i have the 12v into the power supply by the lighter socket and then i have the ATX cable from the PSU to the motherboard.
Im using a ITX MII 6000 with a 600mhz fanless cpu so its not draining to much it wont start.
They only have a 60watt car psu on there website
http://www.morex.com.tw/PDF/Installa...0Cigarrate.pdf
That is what i got but the to power button wasnt on my sheet.
Then there is this one about hooking it up to the battery
http://www.morex.com.tw/PDF/Installation_Guide.pdf
It mentions the 4 pins on the board which i gather pin 1 and 2 go to the motherboard and pin 3 and 4 go to a button to turn on the PSU which turns on the Motherboard.
I had it hooked it and flicked the motherboard switch then i pressed the 2 contacts on the PSU that says switch to the front and it didnt do anything
makes a WINE noise when i push power on the motherboard and i pushed both contacts on the board where it says switch front panel but still nothing
Does anyone have any idea?
NiN^_^NiN is offline   Reply With Quote
Sponsored Links
Old 09-04-2004, 11:40 PM   #2
skippy76's Avatar
Vehicle: Jeap Liberty
My Photos: (0)
My only comment at the minute is that if I understand you correctly you are not using the power switch, you are simply shorting across the two pins. I believe this needs a certain restiance rather than just shorting!
06 Volvo XC90
Use to have installed MII 10000/512Mb/40GB, Lilliput 7", OPUS 90W, Wifi-G PCMCIA, Head Unit Aux adapter, Delorme GPS, XM PCR, Audigy NX, RR
Car PC downloads: http://carpc.harteveldt.com/
skippy76 is offline   Reply With Quote
Old 09-04-2004, 11:52 PM   #3
NiN^_^NiN's Avatar
My Photos: (2)
But a power switch from the PC is the same as shorting.
I just modifyed a CD audio cable for the soundcard to connect from the PSU to the motherboard and i use the other 2 wires to start the psu and mb as shown in the second PDF and all i get is a WINE noise still
Im still just shorting the to wires to start it but i get the wine but i short the pins from the PSU which makes the wine noise which only happened when i made the motherboard start up so it seems like the cable does make the motherboard switch go but it just wines nothing else
[edit]
On the DC hub a guy mentioned that the WINE noise could be that there isn't enough power through the lighter socket so i tryed it in another car and still the same so i dont know whats wrong maybe its a bad PSU ???
[edit]
Sponsored Links
vB code is On
Trackbacks are Off
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 06:25 PM
Morex 80W Car PSU Tred Power Supplies 48 10-15-2004 02:53 AM
PW60 > Morex PSU? Dominik Power Supplies 0 07-14-2004 07:33 AM
morex psu noise fix starfox Power Supplies 2 03-15-2004 07:19 PM
What to look for in a PSU some info for you cproaudio Power Supplies 9 04-04-2003 01:07 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
