Old 09-11-2004, 06:05 PM   #1
EBJUSTIN
ITPS Startup Shutdown Controller Not Working
I bought the ITPS from MP3Car.com a couple months ago to use solely as a startup/shutdown controller cannot get that to even work properly. The problem I am having is that the ITPS will turn on my computer when ignition is applied. I tested this in the car and on the bench. I connected an oscilloscope to see PWR_ON output (connects to motherboard power jumper) of the ITPS. As you can see from the capture the turn on pulse is only 344nS which is way to short for the motherboard to detect. Has anyone else had similar problems with their ITPS?
Ch1: Input Voltage to ITPS
CH2: ITPS Pwr_On Output 1
CH3: ITPS Pwr_On Output 2
Ch4: ITPS Ignition input
My Celica Carputer Install
EBJUSTIN is offline   Reply With Quote
Old 09-11-2004, 06:28 PM   #2
EBJUSTIN
1.10.6.7 Power On Connector
This connector can be connected to a front panel power switch. The switch must pull the
SW_ON# pin to ground for at least 50 ms to signal the power supply to switch on or off. (The
time requirement is due to internal debounce circuitry on the motherboard.) At least two seconds
must pass before the power supply will recognize another on/off signal.
Old 09-11-2004, 06:58 PM   #3
Raw Wave
Ricky327
That dont look right.
Yup for the motherboard to turn on/off the ITPS should be pulling it to the ground. Have you tried the ITPS without the motherboard at all? to see if the ground-pulling does actually work...you may need to use a 10K pullup resistor to see this working properly.
Nice scope you got there...what is it?
Ricky327 is offline   Reply With Quote
Old 09-11-2004, 08:54 PM   #4
EBJUSTIN
The scope capture was taken without the motherboard. It probably does need a pullup reistor if it is an open drain output.
The scope is a LeCroy Wavepro950
Old 09-11-2004, 09:04 PM   #5
Raw Wave
Ricky327
LeCroy Wavepro950 priced at 22,500 USD?
Do a search on ITPS...Im sure someone did had the same problem as yours before, cant remeber who.
DSSC startup / shutdown controller available dashpc Power Supplies 0 04-18-2004 10:00 PM
PW70a w/o ITPS startup, shutdown, and more! cybermob2 Power Supplies 5 03-23-2004 04:25 PM
Startup pulse fix with Jeff Shutdown Controller moahdib Power Supplies 2 03-03-2004 12:51 PM
Working BX-24 startup controller droswell Power Supplies 2 12-18-2003 06:23 PM
startup shutdown etc. marsjell Power Supplies 6 06-19-2002 07:07 PM
