Old 11-23-2004, 01:33 AM   #16
ColdPhreze is on a distinguished road
MrPerfectionest, yes, this is from my professional experience working with power supplies over the years. When you push any device that creates heat to the manufacture's stated limits, components break down at a much faster rate than normal. Power production vs. component breakdown is an exponential curve. At 150 watts, an OPUS is being strained, any more and severe strains occur. That 150watts is it's maximum continous power, which is going to generate more heat, and stress certain components to their maximums. This will *always* lead to a decreased lifetime. If you keep below the maximums, you will prolong the lifetimes of any heat-creating product.
Let me put it this way: Consider an automobile which is designed and rated to operate safely at 6000rpm, and red-lines at 6500rpm. This means it is ok to rev to 6000 rpm, and even up to 6500rpm occasionally. However, does it mean it is ok to constantly run it at 6000rpm? NO! You will blow that engine in a short amount ot time, even if you change the oil and other fluids every day.
I stated that blanket rule, then also stated that you have to look at every rail separatly... Thus driving home that one must consider both total power and individual rails.
Opus isn't lying, their product does output a constant 150 watts. The only thing that wasn't considered or told to those purchasing it, is that it's life expectancy is reduced at that wattage.
Consumers should be better informed... but that is kinda the point of this forum
ColdPhreze
14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
ColdPhreze is offline   Reply With Quote
Old 11-23-2004, 01:42 AM   #17
choyak's Avatar
choyak is on a distinguished road
At my work we make AC-DC-AC converter systems rated more than 60 kilowatts and they are near 90% efficient. The AC-DC is a PFC and the DC-AC is an inverter using IGBTs. I see no reason that DC-DC is at least 90%, depending on the topology. The weirdness to circumvent though is it is either dual stage or flyback. This is necessary because the DC-DC needs to both buck and boost.
Carputer currently 'ghettoed' into car!!!
EPIA MII-12000
Ampie Case with rigged extra USB
Hitachi 60GB
Holux GPS mouse with iGuidance 2.0
Lilliput 7" touchscreen
Netgear WG121 USB WiFi
Carnetix P1260
choyak is offline   Reply With Quote
Old 11-23-2004, 12:22 PM   #18
MrPerfectionest is on a distinguished road
I know what heat does to components.
I am talking about specifications plain and simple.
Opus states that their device will deliver:
+3.3V: 10A max, 13A pk, 50mV p-p max 2%
+5 V: 10 A max, 13A pk 50mV p-p max 2%
+12 V: 5 A max, 6.5 A pk 50mV p-p max 2%
-12 V: 0.5 A max, 1.2 A pk, 150mV p-p max 10%
5 V standby: 1 A max, 1.2 A pk 50mV p-p max 2%
from -20C to 70C with a MTBF of 150,000 hrs. They also provide a limited 3 yr warranty.
This is their specification and I will live by this. If my application stays within those ratings then I fully expect to be able to turn my opus on and have it run for 17 yrs. This may not be realistic (and I would be interested to see how they arrived at that number) but Opus states they will warrany it for 3 years. So at the least I can expect that or else they replace the product, plain and simple. Thats all there is to it.
Your analogy doesn't work at all because when a mfg. produces a car the 'specification' (I use the term loosely here) is 'normal' driving conditions. Normal driving conditions aren't 6000rpms 24hrs a day.
MrPerfectionest is offline   Reply With Quote
Old 11-23-2004, 12:38 PM   #19
Raw Wave
Ricky327
What is the "normal" condition for the OPUS?
Ricky327 is offline   Reply With Quote
Old 11-23-2004, 12:53 PM   #20
rushnrockt is on a distinguished road
Hey there MrPerfectionest,
Although one would think that the numbers given by a PS manufacturer for each rail should add up, it is not quite the case. You probably noticed that for example regular cheapy PSUs out there rated at 380W cannot compete with say an Antec 300W. The reason is that the cheapy PSU's looked at each rail separate and added up the numbers to get their power rating. In reality, with all rails loaded at the same time, power supply is strained to keep them going, hence the '80%-90%' rule mentioned previously. I am an electrical engineer (granted, only beginning) and as far as I can see, any rating that a product has is quite idealized, and since OPUS doesn't say what kind of load they use, its definitely a great idea to be on the safe side.
rushnrockt is offline   Reply With Quote
Old 11-23-2004, 01:30 PM   #21
MrPerfectionest, I agree with rushnrockt, what are "normal" operating conditions for an opus? I am SURE that the norms are not to constantly pull the maximum continous currents for 3 years, so my analogy holds true. And, any idiot knows that specs are idealized, and that you cannot expect to constantly pull their max continous rated values for long. It's called marketing.
Also, why do you ALWAYS argue with me? You seem to be making a habit of it.
ColdPhreze
Old 11-23-2004, 03:00 PM   #22
Because you know just enough to be dangerous. Someone that doesn't have a clue will read what you write and think it is gospel. Then in the face of irrefutable facts you will cling to your original arguments or morph your statements into something that you claim wasn't "totally incorrect" (reference the thread about "car frames").
This is what I mean, you have chose to focus on my word choice of 'normal' and then tried to change what the meaning of 'normal' is the way I used it. You state that normal isn't 3 years of continuous operation. Of course that isn't what a normal computer user would consider normal every day use but you completely took my useage out of context.
I am talking about specifications. You do understand what a specification means in the industry right? I take normal use to be anything that falls within what Opus says the device will do. Opus states it will deliver the loads I posted above, within the operating temperatures they state, with the input voltages they state, and it will do it for 150,000 hours on average before failure. If their product doesn't do that then their specification is lying and as a consumer you have plenty of reason to complain.
There is no reason at all to think semiconductor based devices operating WELL within their specified ranges can't run continuously given that they stay in their operating ranges and capabilities.
I am fully aware of this. The car stereo makers have been doing this years and will use all the tricks in the book to inflate their specifications. This is nothing new. But, we aren't talking about commodity AC-DC power supplies here. The commodity market is an entirely different animal than the niche the Opus is fulfilling. In the commodity market it is marketing. Corners are cut, lots of tricks are pulled to make that .50c-$1 margin that they are making on their product. They know enough people will be buying their products that won't be operating near the limits and they know most educated consumers that are looking to push the limit aren't going to buy their product. So they avoid a potential quality problem this way. Within this market you will find companies that produce respected supplies that will do what they say they will do, and you pay for it too.
The Opus is not in a market where they can produce a product that won't do what it will claim. They will lose business quickly if their product doesn't perform. They even go as far as offering a 3 year warranty on their product, and yet you question whether it will do what it says it will do???
As am I with plenty of years in the industry.
If Intel or Sun or HP or any of quite a few other companies came back to my company and asked why our devices broke and we told them this my multibillion dollar company would be out of business very quickly. What we put on the spec is what our device will do, and we are even IN the commodity market.
Old 11-23-2004, 04:19 PM   #23
MrProfectionist, it seems you are the one who is taking the dangerous grounds, suggesting to the audience here that they stress their psu to it's maximum ratings, while I suggest not to. You stated "If my application stays within those ratings then I fully expect to be able to turn my opus on and have it run for 17 yrs. This may not be realistic...", so who is being dangerous with their knowledge?
I'm not getting into it with you about car frames again. My local automotive mechanics agree with me, I don't care if you do. Who knows more about frames, you or a mechanic? Don't answer that, it's retorical.
I do understand about specifications, I just don't believe OPUS's are completely true. I beleive they have fallen victim to marketing ploys, and they will still remain as a company because it's the only decent DC-DC with a sdc. There is no competition, so that niche market you're talking about will still buy their product even when it is problematic because there is no better, and because so many people diss using an inverter like it's bad or something, while the rest of us using inverters attempt to warn (and when they won't listen we laugh at) those overloading an OPUS.
Actually, normal computer use for me and most of the people I know is 24/7 always on. Of course, that is different in a car computer, and I did not here make the distinction. But I didn't need to, because you stated that bit about 17 years and using it at max rated continous values, which suggests you will be leaving it on 24/7.
Opus doesn't specify their "normal" use, so really this argument is for naught, except that IT IS WISE for the consumer to err and be on the safe side. In the very least, DON'T overload it.
As for Intel or Sun or HP or any other large company... Those circumstances are different, just as you state this niche market is. Most retail consumers don't know enough to test a psu to verify if they do what they are rated, so companies can strech the specs wthout any major reprocussions. Commercial consumers, however, will put it to the test.
If you had as much electronic engineering experience as you profess to, you shouldn't be arguing with me about erring on the side of caution - it is a good engineering practice. You should always take the manufacturer's worse case specs, and make them doublly worse to assure that they will operate properly in your application. If you need more current, it's not like OPUS is the only thing out there. You can always use a SDC and Inverter, you won't have any problem if you buy an inverter of 400watts rms or more.
ColdPhreze
Old 11-23-2004, 04:38 PM   #24
May be (here is a brand new idea) instead of going after fellow enthusiasts with idealistic assumptions, you should go out there and find out what exactly OPUS believes its normal conditions are. I am not into taking sides, but ColdPhreze was correct about the "80-90%" rule for power supply loading. I've been around Computer modding longer than I've been an EE, and if you were to check out power user recomendations, the load they put on the supply is always less than the theoretical number, since you can never predict what kind of a power surge you might have at some instant. You can call that insurance.
Now if you really want to prove everyone wrong, get one of those OPUS power supplies, set it up in the lab that I am sure your company has, and load up each one of the rails. To make it more interesting, switch loads on and off at random, and see the power spikes and dips, my guess is that at full 150W load, you will find some discrepencies from the numbers provided by manufacturer.
By the way, this is not from engineering classes, but business clases, when you are the only player in the market (niche or not) you get to say whatever you want, its not like non-existing competition would say anything about it
P.S.
What I think OPUS should do... is have a person checking on all these posts from time to time and actually have "official" input on the matter. I think it would help their business out if they were here trying to clear out whatever misconceptions we as users might have.
Old 11-23-2004, 10:15 PM   #25
I had to type that post twice and forgot a bit of information the second time. The original post said that even though Opus states 150,000hrs MTBF that I was curious about how they arrived at that number but at the very least they give a 3 year warranty (I did state that) and I would expect to be able to run the device this long at least.
But the post I did make added the claim about semiconductors operating in their safe regions will last forever.
You say this:
then say this:
which clearly shows you have no clue what a specification is. Please get this concept iinto your head. A specification is the law when we are talking about things of this nature. From dicitonary.com:
Quote:
specifications A detailed, exact statement of particulars, especially a statement prescribing materials, dimensions, and quality of work for something to be built, installed, or manufactured.
I know very well what what goes into dc-dc converters and though I haven't given a full evaluation of the design, a glance at the components is enough to have a good idea that it will do what it says it will do. It isn't hard to acheive the design they have (I have some designs of my own that outdo theirs that aren't overly complex) and if they don't meet the ripple specification (wow there is that word again) set forth by the ATX standards committee then there is a good chance whatever is attached to the Opus simply won't run at the specs they say.
If I worked for Opus I would be insulted by this comment. What gives you the basis to make this statement? People attaching multiple hard drives, lcd screens (these three alone probably enough to put us over the 5A rating on the 12V line) and other devices causing the Opus to break is certainly not a basis to make this claim. What answer do you have to the many multiples of people that have the Opus and are totally satisfied with them?
You have a somewhat valid point about them being the only supplier but if their product is as poor as you claim then plenty of people would already be off the bandwagon and buying into other solutions (mainly a seperate supply and sdc) which are almost as feasible to implement and not too much more expensive.
I'll assure you it is as much as I profess and probably more.
Finally you hit on something correct. The biggest problem is your whole experience (btw, have you ever owned an Opus) is based on AC-DC converters from the desktop world and you use this as a basis alone for the claims you are making against the Opus. Had you any real experience in the industry you would realize that your 80-90% claim (the cause of this whole discussion) in regards to the Opus is ridiculous.
My job everyday is to make sure that our customers don't get failing devices. To do this we test guard band into the product. This way we get rid of all the devices that are borderline on our spec. and only ship those devices that fall well on the good side.
This can be easily seen in the peak ratings that Opus puts on each individual line. This is the guardband they are building into the product. They also limit the temperature range to 70C. Probably every component in the opus has a rating of at least 85c, some will have 100c and a few will even have a 125c rating. Since it is a switching supply it will be low in heat by nature. At 90% efficiency it is wasting 15W of heat at full power. At 70c (their max spec) 15W of heat distributed across multiple regulators isn't enough given proper heatsinking (which the Opus has) to raise the internal temps of any of the devices near high enough to become critical.
Again, this statement is based off of your AC-DC supply experience but it is pretty much taken care of with the peak rating given to us by Opus. Besides, if we buy components (hard drives, screens, etc) and add all their max ratings and keep the total less than the Opus spec then we are fine. The hard drive won't pull more than it claims it will or will you assume that hard drive mfgs are lying about their specs also? This dc-dc supply probably runs in the 200khz range or more for all the regulators and is plenty fast enough to handle the transients thrown at by any device connected to it.
There is existing competition and again, If I were an Opus employee I would be bothered by both of your assumptions that they are trying to be purposefully misleading.
YOU CAN'T ARGUE WITH A THREE YEAR WARRANTY OR THE FACT THAT TONS OF PEOPLE ARE HAPPY WITH THEIR PRODUCT AND THEIR SERVICE IN THE EVENT OF A FAILURE.
How much more does it take?
I would love to entertain a well thought out post with good reasoning to support your claim.
Old 11-23-2004, 10:47 PM   #26
MrPerfectionist,
I have a HUGH responce to all of that, but once again, I tire of arguing with you. It is like talking to my 2 year old. You are too thick-headed to fully understand what I say, and too hot-headed to reason with.
Once again, I will refrain from replying to you again, as this is going nowhere. You obviously have your opinion, we all know this. I know you are simply trying to live up to your name, but lets face it, you aren't perfect.
Goodbye
Old 11-23-2004, 11:15 PM   #27
auto_robotics is on a distinguished road
Yikes. This thread reminds me of some of the politics forums I frequent.
Anyways, I'll leave the power supply spec details to your expert judgment. I'm an electrical engineer too, but for me that largely means a concentration in control theory and digital signal processing.
Mr.Perfectionist: You asked what I was using power for a while back? Short answer is I'm a bored engineer who likes projects on the side of work. I've developed a few algorithms in C to find lane markings on a highway. I want to hook up a camera to my computer with a frame grabber card, do some image processing and develop a lane departure warning system like on some luxury cars. I could go with DSPs (and may well later), but a nice simple way to crunch some numbers is through a decently fast P4.
Next step from there is using GPS and actuators on the steering column and pedals to do waypoint navigation (another thing I've already developed code for). It works in simulation! Haha, famous last words of the engineer.
auto_robotics is offline   Reply With Quote
Old 11-23-2004, 11:36 PM   #28
Its amazing really.
I systematically tore down your claim with extremely good factual based reasoning, yet you refuse to admit that you are incorrect. And I am the hard head?
Here, because I enjoy this and am bored, we can walk through it and please if I am wrong somewhere along the way point it out.
Quote:
As a rule-of-thumb, you will severly shorten the life of a PSU if you draw more than 80-90% of it's stated capacity. Following that rule-of-thumb, you can safely draw 120-135 watts from an OPUS (these a approximate, but are a good practice when designing a PC). Also, remember that you could be pulling more current on one rail than it is designed for, and much less on another, still be within 120-135 watts, but the PSU won't last becuase that one rail being stressed will die.
So you make the statement about only 120-135W as a general power consumption, but you confounded your own claim with the statement about stressing one rail. The second statement was correct and could have stood on its own.
My guess is you will attempt to claim (this is your change the argument/claim strategy) that by the 80-90% safety factor you will protect all rails from being overstressed. This too can readily be shown to not work in all situations.
I asked for more support of your claim and addressed the part about a general power consumption number.
Your experience is based on AC-DC power supplies which the Opus is not and exist in an application and market entirely different (which I explained a couple of times).
While the spirit of this statement is ok (that more heat can cause more failures), it is based on other devices that may or may not be similar similar to the Opus in their built in robustness. Yes the curve gets exponential near the edge. But the only component you consider is the Opus itself and you go by a single 150W number as given by the manufacturer. What you don't understand is the technology that is actually in the Opus and your blanket statement about component failure can't be readily applied to the 'system' that is the Opus.
You don't have to consider total power if you consider the individual rails alone, this concept alone nullifies your original 80-90% claim (among other things).
Its amazing how you know this information and can make this claim despite Opus saying the MTBF (thats 'mean time before failure' in case you didn't know) is 150,000hrs. Even if they fudge this number by a factor of 10 (pretty absurd don't you think?) the device can still be expected to live for almost 2 years at their ratings. On top of all this they give you a three year warranty.
I gave tons of other good reasoning supporting why I think your statements are completely and utterly baseless. In general your failure to respond is enough for me and hopefully others reading this post to realize you were wrong.
The point of all this that as long as a user of the 150W understand what his power draw is and stays just under the current specificationf or each rail (generally speaking it is probably even ok to go a little outside of it) they can expect their device to last quite a long time.
As if your failure to respond isn't enough, your resorting to name calling certainly is.
What is most funny is the fact that my name is spelled incorrectly on purpose, it is simply an ironic name. You missed that one too.
Old 11-23-2004, 11:41 PM   #29
Alright Mr, you like to quote, lets quote (but do read to the end please)
So for starters, regular power supplies have their MTBF calculated at 25C... and even though these are conservative numbers, it is possible that some people had it running for extended period of time at temperatures higher than that, thus lowering the MTBF. And yes, MTBF is calculated at a single temperature, not sweeping the whole operational range. And YES, MTBF is calculated at the still elusive optimal conditions.
Now that's just silly, did you ever notice how many cars out there don't have the stated horsepower even though it is measured and certified by the government? same goes for their mileage... so moving on.
As stringent as ATX standards committee and its armed minions are, many PC enthusiasts can show a messed up power supply or two that still managed to power their entire computer systems.
Alrtighty Mr. Eager Pants, I was not on the Opus bashing spree here, I was suggesting different reasons Opus supplies that DID fail have failed for. Overloading was one of them...
Now that's just flame war. I never staed how "poor" they are, in fact in all the posts I've had on this forum, my only complaint with them is that I wish they were cheaper. You have to remember that all this started with you claiming that "80-90%" rule is basically nonsense. If any blame was being spread to begin with, it was with the users for overloading the supplies, and you seem to be backing up that point of view as well.
I will now skip the whole AC-DC discussion, even though its amazing that you seem to think that AC-DC conversion brings so much more to the table that it does not compare to DC-DC in anyway. I will also appreciate if you refrain from commenting on this, since we can have this (lengthy) discussion elsewhere.
Next on...
There is again, difference between typical consumption (optimal conditions) and max operating conditions. Put extreme conditions (temperature, caused by poor ventilation and/or bad placement) together with full load (all power ratings taked at "optimal" conditions as opposed to for example watching DIVX movie) and poor Opus power supply is dealing with more than any engineer intended it to do. Hence "80-90%" rule, you know, to protect from overzealous geeks.
There is existing competition and again, If I were an Opus employee I would be bothered by both of your assumptions that they are trying to be purposefully misleading. YOU CAN'T ARGUE WITH A THREE YEAR WARRANTY OR THE FACT THAT TONS OF PEOPLE ARE HAPPY WITH THEIR PRODUCT AND THEIR SERVICE IN THE EVENT OF A FAILURE.
Sooo, AGAIN (in case you missed it before) no one is claiming that Opus is all around bad. At the same time, as you probably noticed with product recalls, faults do happen with a percentage of manufactured goods of any kind, no matter the quality control. And when the product is used by adventurous techies and "standard operating conditions" are wide open to interpretation... you can guess the results. And yes, it is possible to argue with a 3 year warranty, it is not exactly like God said "let there be light... and Opus power supplies never failing under any circumstances." Especially he didn't say that about LIMITED warranty.
So to sum this all up, for an engineer at your level, I am surprised that you would argue with some extra precaution in putting together a system, especially out of parts that are mostly meant for enviroments other than a moving car. Now here is my challege for you, how about you entertain an idea of putting up a post without actually insulting someone? You might think that you are "just presenting facts" but from your first post and to the last post, you are squirting anger of some sorts. I came to this forum for some ideas and support in my project and I would think that someone with your experience would have been of great help, yet from what I see, the only thing that I am guaranteed to get from you is belittling... I hope you can prove me wrong. Regards
Old 11-24-2004, 12:31 AM   #30
I challenge you to point out an insult.
I fail to see how you can mistrue rebuttals to someone elses claims, backed by more experience, and more logical reasoning as an insult.
For starters, we don't know how Opus did their MTBF. I would like to know where you got your 25C number from. There are a couple of different methodologies used to arrive at this number. I would hope that they would be calculating this value based on the typical target system which 25C certainly is not. If we assume that Opus isn't being fair then you have a case, but otherwise no.
I wasn't talking cars, I was talking semiconductors or anything else that relies on standards. A spec is the law.
For one, I am not sure what you are saying. Are you saying that a psu that doesn't meet spec can power a computer system? Secondly, I don't understand why you are calling the ATX standards committee 'armed minions'. This goes back to the apparent distrust you and ColdPPhreze have. This distrust apparently stems from desktop AC-DC supplies, and rightfully so, to which I gave plenty of analysis for why Opus doesn't fall under this category. The standards committee is there and necessary to keep your costs low, so why do you villify them?
You quoted me on a comment I made where I was not quoting you. I would fully expect the supply to fail if operated far outside of its specified range. Is that enough justification to operate it WELL below its specified range and to make claims about Opus not being truthful?
Again, I didn't quote you.
You aren't understanding my argument. The market dynamics for AC-DC supplies (consumer desktops) by its very nature will contain the type of products that cause power supply skepticism. The Opus supply doesn't fall in this category and shouldn't incur the same level of cynicism.
Specifically:
If the supply is operated within the specification (what I have stated over and over and over again) set forth by Opus, then it will live and be happy about it. If you want to mix qualitative and quantitative metrics and theoretical assumptions about the operating environment, I can always argue that it is a very rare case that the opus is operated in a 70C environment AND I can also consider the peak rating Opus gives us (which is definitely higher than the 150W rating) which will null this 80-90% statement.
You can make basic claims based on knowledge of other things and I can make claims based on intimate dc-dc converter knowledge and an examination of the Opus design itself. Who wins out?
I never made anything to the contrary. But claims are being made that supply can't do what it claims it can do.
Of course. Customers of said goods (Dell, IBM, etc) tolerate a certain number of DPMs that we agree upon. If we don't we lose out to other suppliers in the game.
Hold on now. I have never made an assumption about pc components in a car. That is a whole different can of worms.
AC or DC power supply w/ tablet pc? gutterslide Power Supplies 2 04-07-2004 04:12 AM
what is the cheapest DC to DC ATX power supply available? Squeezer Power Supplies 9 07-29-2002 02:17 PM
What are the ATX DC to DC power supply options? Squeezer Power Supplies 6 07-08-2002 05:25 PM
dc or ac power supply qball008 Power Supplies 0 05-16-2002 11:22 PM
dc to dc ATX power supply Kaizer Soze General Hardware Discussion 10 10-21-1999 08:47 PM
