Old 10-11-2004, 03:57 PM   #1
bobthebaker is on a distinguished road
temporary carpc, will this power setup work?
basically, i'm using a laptop i have lying around as my temporary carpc until i build one. I'll be using an 8'' lilliput with it.
For power i'm going to use this adapter i got that plugs into my cig lighter and splits the connection so i can use both an AC source and a DC source (and also acts as a half-assed surge protector)
I plan to use the AC portion of the splitter to power the laptop, and the DC portion to power the lilliput.
Few questions i have about this are:
1. will this be safe for my cars battery? I know my headunit turns off temporarily when the ignition starts, but does the cig lighter?
2. By doing it this way, i know i'll have to manually turn on my laptop everytime i want to use the carpc.......anyway i can somehow get the laptop to turn on by itself with this setup?
here's the product:
http://www.tigerdirect.com/applicati...4004&CatId=237
bobthebaker is offline   Reply With Quote
Old 10-11-2004, 04:21 PM   #2
no1knows's Avatar
no1knows is on a distinguished road
depending on your laptops power supply and that products ability to produce a clean AC curve, yr laptop should work fine, although i would say try to find a laptop DC-DC converter, they are more efficient and will probably work better.
As for getting the laptop to turn on, there is a lot of information on this board, shutdown controllers that use the parallel port can be used to turn it off, as for turning it on, if the bios doesnt have a boot on AC power feature u may need to do some soldering to the power button connecting it to an ITPS or shutdown controller of yr choice (or relay with the ACC line).
HTH, no1knows.
Mods: 18" Boss rims,Twin custom stainless exhaust,cold air induction.
Sound: Pioneer 7400 HU & 6x9's,12" Vibe Sub,600W Kenwood amp.
CarPC: MicroATX, Inverter, WinTV, Lilliput 7", USB GPS
http://www.no1knows.com/galleries/
no1knows is offline   Reply With Quote
My 2001 Sport Trac Install wkolodny Show off your project 84 01-30-2008 11:18 AM
How2 control CarPC from key fob.... NotchbackVW Power Supplies 1 09-21-2007 06:27 PM
Nubee, what is a fail safe power setup for a m10000 with... mdrt4me Power Supplies 0 05-18-2004 08:38 PM
mobo does not support resume on power loss ashbosh General Hardware Discussion 3 05-18-2004 10:49 AM
Will this setup work? Sound of Silence General Hardware Discussion 1 12-10-2000 08:22 AM
