The MP3car.com Store
Thread Tools Display Modes
Old 10-14-2004, 06:33 PM   #1
My Photos: (0)
OPUS 150w keeps killing my battery. Need help!
Hey,
I have a custom pc in the trunk of my vw passat. I have the OPUS 150w PS correctly connected between the PS and the Mobo. I have the RED wire (12v battery) powered from the factory radio's harness which in VWs, gives power even with the key off, so I use the radio spot in factory fuse box as a computer fuse now. Then I have the YELLOW wire (trigger) running to a switch, which gets its power from being tapped off a cigarette lighter. The BLACK (ground) wire taps into the cigarette lighter ground.
Anyway, when I flip my switch to turn off the feed to the yellow wire, the computer shuts down as expected "Windows is shutting down" follows by the mobo turning off and the OPUS status light blinking once every 3 seconds.
Here's the problem. When I don't drive my car for a couple of days, it won't start! I would boost it with a power pack I have in the trunk, drive around for a long while, then when I would turn it off the car still wouldn't start the next time. In order to diagnose the origin of the problem, I unplugged the OPUS compeltely from the car and every since the I've had ZERO problems starting the car.
Does anyone know how I can cure this problem? The whole point of buying the Opus was to be able to have windows shut down normally when I turned off the acc. switch. I also thought the Opus was supposed to protect your battery from dying. I thoguht about just wiring both the yellow and red wires up to my switch, but that would defeat the purpose of having the opus in the first place because as soon as I'd turn the switch to the off position, the computer would abruptly shut down, which is something I obviously don't want.
Thanks for any help you can offer!!!
Eric
EuroFan is offline   Reply With Quote
Sponsored Links
Old 10-14-2004, 07:31 PM   #2
bosstone74's Avatar
Vehicle: 2000 Civic EX
My Photos: (0)
Quote: Originally Posted by EuroFan
Hey,
Eric
YOu should have the red wire going to the possitive terminal on the battery, the black going to the neg. the yellow should go to anything that has a 12v during cranking and as well as running.
BossTone74
bosstone74 is offline   Reply With Quote
Old 10-15-2004, 07:56 AM   #3
My Photos: (0)
The way you've got it set up should work.
If the opus is faulty then it may just require replacing. If you are draining the battery and nothing is switched on then you could have a short circuit, this problem could lead to your car not only being drained of battery, but also being surrounded by firemen next time you return.
I;d get a multimeter and see if there is any voltage going through areas that you didn't expect it to be.
Matthew230 is offline   Reply With Quote
Old 10-15-2004, 08:20 AM   #4
samc's Avatar
Vehicle: 2002 Jetta 1.8T
My Photos: (0)
First off,
I would suggest you power your opus (red wire) off your cig-lighter plug. That is also constant on and your HU power wire is rated for 10A draw, your opus will want 15A at times. (blown fuse). And the yellow can connect to the red wire off the hu harness which is the ignition on wire. Ground just go crazy.
And then I would measure the current draw at both wires.
Mine needs to be updated.
samc is offline   Reply With Quote
Old 10-15-2004, 10:17 AM   #5
bosstone74's Avatar
My Photos: (0)
Quote: Originally Posted by samc
First off,
Why would someone NOT follow the OPUS instruction and hooked it right the the battery?
BossTone74
Old 10-15-2004, 10:31 AM   #6
Vehicle: Skoda -99
My Photos: (0)
i would not recommend connecting the Ground cable directly to the battery ..
The older you get, the more expensive your toys get
Mogwai is offline   Reply With Quote
Old 10-15-2004, 10:43 AM   #7
Bootbox's Avatar
Vehicle: 2002 Ford Focus ZX3
My Photos: (0)
Do you have a lot of USB devices? I'm pretty sure that the 150W opus doesn't cut power to the USB stuff when it's shut down, that could be draining your battery.
My Car
Bootbox is offline   Reply With Quote
Old 10-15-2004, 02:06 PM   #8
bosstone74's Avatar
My Photos: (0)
HELLO...YOU ARE SUPPOSED TOO!
BossTone74
Old 10-15-2004, 02:14 PM   #9
Super Moderator
xBrady's CarPC Specs
xBrady's Avatar
Vehicle: 1999/Volvo/S80
My Photos: (1)
Mine isn't.
Installed.
-GPSSecure- - GPS Tracking
xBrady is offline   Reply With Quote
Old 10-16-2004, 01:08 AM   #10
Raw Wave
rando's CarPC Specs
rando's Avatar
Vehicle: 2004 Toyota 4Runner
My Photos: (0)
To be compliant with the ATX specification, the Opus 150W ALWAYS powers the +5VSB rail. Depending on your specific motherboard and peripherals, you may be consuming upwards of 5W here -- more than enough to drain your battery in just a few days. You can override this behavior with a relay and a few diodes. Search the forums.
Also, though unrelated to your power drain issue, you should consider a more appropriate power and grounding strategy for your Opus. It is unlikely that your cigarette lighter power circuit can provide adequate power and ground. As specified by Opus, you should run a dedicated 12G or larger circuit (fused) from the battery. You should use a 12G or larger ground wire running back to the battery ground or to the nearest GOOD ground point (bare metal with a bolt). Your turn-on circuit sounds fine.
Good luck.
2004 4runner
rando is offline   Reply With Quote
Sponsored Links
Old 10-16-2004, 01:11 AM   #11
archimense's Avatar
Vehicle: 01' Audi S4 Twin Turbo / 00' VW Jetta VR6
My Photos: (0)
I followed the info in some of the posts Rando made about disabling standby power, and it solved the power drain problems my OPUS 150 was causing in my VW.
Jetta Install Photos
Audi S4 Worklog
01' Audi S4 Twin Turbo / 00' VW Jetta VR6.
archimense is offline   Reply With Quote
Old 10-16-2004, 08:29 PM   #12
Vehicle: 93 Toyota Celica Conv
My Photos: (0)
I'm considering buying the 150w opus but am concerned about the 5V standby current draw. The opus users manual states that the opus can consume from 1 to 8 watts when the standby jumper is placed....8watts equates to 667mA @ 12V which will drain the battery too quickly. Has anyone measured the the standby current draw from the opus while powering an Epia M10k in standby without USB devices attatched. Currently I have a separate 5VDC regulator powering the +5VSB to the Epia M10K. I measure ~150mA at the battery.
My Celica Carputer Install
EBJUSTIN is offline   Reply With Quote
Old 10-16-2004, 09:27 PM   #13
Avalerion's Avatar
Vehicle: 2006 Toyota Matrix XR
My Photos: (0)
Forget the above answers. They all make no sense. This is what I did, and if you need pictures, let me know.
1. Connect Red Wire +12 to positive battery terminal.
2. Connect Black Wire Gnd to negative battery terminal.
Make sure you have a fuse near the battery on the + line.
Go to radioshack and get a switch (20a-30a) along with some quick disconnects.
Install the switch somewhere in the car, with the red wire connected to it.
When you're not using your car, keep the switch off. It prevents any power from leaving your battery and turns off the Opus. It's the same as if you were removing the black power plug from behind your pc. If it's not plugged in, it's not using power. So after you shut down, just turn off the switch. Takes 5 seconds, and you don't lose your battery nor do you wear it down.
Avalerion is offline   Reply With Quote
Old 10-17-2004, 01:45 AM   #14
archimense's Avatar
My Photos: (0)
If you guys would you would see there has already been lots of discussion on an automated and reliable way to do this...
Audi S4 Worklog
Old 10-17-2004, 01:50 AM   #15
Raw Wave
rando's CarPC Specs
rando's Avatar
My Photos: (0)
The 150W Opus does not have a jumper to configure the +5VSB rail. It's ALWAYS ON. Only the 90W Opus has this option.
2004 4runner
Sponsored Links
vB code is On
Trackbacks are Off
OPUS 150 low battery shut down archimense Power Supplies 12 09-08-2004 03:28 PM
Help with Opus 150w hook up for newbiee... jedi7001 Power Supplies 0 06-08-2004 09:05 PM
Troubleshooting 150W Opus (turns off after 20-30 mins) [iG] Power Supplies 8 06-05-2004 10:13 AM
Closed - Possible Opus Group Buy BoraXP Classified Archive 319 05-18-2004 10:03 AM
Will a 150W OPUS power this? mbkowns Power Supplies 1 04-14-2004 02:17 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
