10-20-2004, 10:17 PM
#1
powering usb hub
I have a 7-port externally powered hub and want to power it from my car (not from the computer). I can't seen to find a simple 12v to 5v adapter - any ideas ?
10-20-2004, 10:26 PM
#2
Raw Wave
Does your mobo have a 5v thingy on it?
10-20-2004, 10:27 PM
#3
Phat Boy
take a 5v line from your PSU silly! THat is unless you have a laptop, or your hub takes more 5v.
My Carputer! (More Car Pics at the end)
2 Kicker Comp 10"
Epia M-9000, 256 MB DDR, 120 Gig HD
Lilliput 7" VGA Touchscreen
Check it out?!
10-21-2004, 12:09 AM
#4
I don't want to overload the power supply - I have lots of usb devices .
10-21-2004, 12:37 AM
#5
I use this for mine: http://www.e-preview.com/products/ch...pter/index.htm .
10-21-2004, 12:43 AM
#6
You can use a chip from maxim as you can get as free part
the chip is MAX831 8-30 volt in 5 volt 1 amp out
PDF data sheet
hop you can use it
Plan for project = 100%
Part the project. = 100%
Built...................= 99%
Finish.................= 99%
Install ...............= 99% -50%
Ditail at 4u2n.dk
Here
03-21-2005, 08:51 AM
#7
Any ideas? Im using a laptop and have a 4 ports hub, but all my devices are messing around when all 4 are in use so i think need to external power the hub. I need to have a sigaretlighter 12v to 5v with 2amps. I searched around but could find a good solution.
03-22-2005, 04:17 AM
#8
Quote: Originally Posted by edikp
very promising... where to buy? and have you had any issues with using this as apower source?
03-22-2005, 04:35 AM
#9
This only seems to power a usb device, not a hub. So you can charge batteries of usb devices.
03-22-2005, 04:47 AM
#10
Right, but if it's a stable 5v output what's to stop you from chopping it up, and splicing it to a power plug?
03-22-2005, 07:06 AM
#11
You're right. I just ordered an Asus MyPal car adapter for A620. It has 5V A2 output, so it must be good to, only 15 euro.
03-22-2005, 06:49 PM
#12
solution: buy 2 X 4 port hubs that dont require a external power source.. slimline ones cost about $15 each
CAR INFO HERE
"He who dies with the most toys, wins".
03-25-2005, 08:19 PM
#13
Raw Wave
I'm going to have to give that a try as well.
Just tried tapping into the 5v from my Opus 150 for the 7-port hub and couldn't get the PC to power up. As soon as I disconnected the hub it powered up again just fine.
Oh well. It's only *another* $15 expenditure..
03-26-2005, 02:14 AM
#14
Why would that help if the issue is not enough power from the USB ports on his laptop to power 4 USB devices?
: Jetway J7F2 1.5Ghz Mainboard : Cubid 3688 : CarNetix CNX-P1260 :
: Netgear 802.11g PCMCIA : 2 x LinITX 7" Screens :
: BU353 USB GPS Mouse : Panasonic UJ845 DVDRW :
03-26-2005, 02:15 AM
#15
Sorry, two questions in one thread.
I take it you were replying to the first one!
| Thread Tools |
| Display Modes |
Linear Mode
