Old 10-28-2004, 10:45 AM   #1
CrazyModGSR is on a distinguished road
how can I wire up power inverter to secondary battery, but turn on when car starts?
I have a 400 watt power inverter that I am going to use for my carputer. It is going to be hooked up to the secondary battery I have in my spare tire well. Problem is, if the car is turned off, the power inverter would still be on. I hate to have to turn the power inverter on and off every time I get in and out of the car. Can I use a relay from the ignition wire, or from the remote turn-on wire of my head unit, so that the power inverter will receive power only when the car is on or head unit is on? I already have a relay hooked up to the remote turn-on lead off my head unit to my 4 amplifiers, so could I simply run an extra wire off that to a relay for the inverter. Any suggestions?
Looking to buy or sell a home in Southeastern CT?
Click here: timfrederick.prudentialct.com
CrazyModGSR is offline   Reply With Quote
Old 10-28-2004, 06:22 PM   #2
dodgetimes2's Avatar
dodgetimes2 is on a distinguished road
Tap into the On/Off switch of the inverter by soldering a wire to each contact (take the inverter apart and access the back of the switch, it's usually a rocker type switch). Then use either your remote turn-on or another ignition-on wire to power a relay that would basically flick the switch on and off for you.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline   Reply With Quote
Old 10-28-2004, 08:31 PM   #3
nickmig is on a distinguished road
yeah, go to radioshack and buy a .5amp 12vdc reed relay. Hook up the +12v REM wire to one side of the coil, and ground the other side to your ground in the trunk. Hook up the switch on the relay to the SPST switch on your inverter. Make sure the relay is normally open..... The inverter will turn on with your ignition.
Why do you have the extra battery? Your gonna have to use some type of switch at the front of the car if you want to be able to use the inverter with the ignition off.
Compaq v6719 Athlon X2 tk-57
Xenarc 7" Dash Install, iGuidance w/ iGPS 500
HD Radio, Powermate, ShuttleXpress, XMDirect, DC/Auto turn on, Pioneer TS-C720PRS, 2 12" MTX BTE's, JL 500/1 and RBC
94.3% of all percentages are made up
nickmig is offline   Reply With Quote
Old 10-28-2004, 08:44 PM   #4
SnyperBob's Avatar
SnyperBob is on a distinguished road
Geez man, 4 amps? That's sweet. You can do like all Nick and dodge said. With that much stuff, have you considered buying a DCCS to power on all of your hardware?
That might make your install and power up go more smoothly
Just a suggestion
SnyperBob is offline   Reply With Quote
Old 10-29-2004, 09:10 AM   #5
I have an extra batt in spare tire well because of my pretty big stereo setup. 2500 TRUE watts RMS. this is not BS watts that are advertised on the amplifiers. I've done the research, and the math and pulling a true 2500 watts RMS just for the stereo, not to mention over 30 neon tubes and accent lights and an underbody kit. the thing is pretty much a mobile club, lol. I so have a stinger relay which is connected between the two batteries and isolates them from each other when the car is off, but connects them as one loop when the car is on, so the alternator can charge them both. thanks again for the help
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
Which wire is power and which is ground in Inverter on/off switch. Relay Question. wonderworm Power Supplies 13 09-20-2004 07:01 PM
car battery experiment A SUCCESS!!! chuckctv Power Supplies 6 08-29-2004 11:18 PM
Here's an alternative power source.... A Boy and his Miata General Hardware Discussion 7 11-21-2000 12:44 PM
Have to switch inverter off and on to power up pc mbowler General Hardware Discussion 10 08-22-2000 12:00 AM
