Old 10-28-2004, 10:45 PM   #1
Milo's Avatar
Milo is on a distinguished road
Epia Mii10000 And A Morex 60w Car Psu
Hey all
Just thought i would pop the question out there seeing as im stumped.
I have a VIA EPIA MII-10000 and a Morex 60W DC DC with regulator
The Power supply boots an old p3 866 with a gigabyte board and a gf2 installed but it will not boot this new board which i thought would have lower wattage requirements then the other board.
When i switch the machine on i get a humming noise coming from the PSU and the fans spin. I have a fujistu 20g HD which i was using but disconnected and still have the same issue.
I know buying a Opus would be the best idea but to get them in Australia anit the easiest thing to do.
If anyones got any ideas at all then im all ears....or eyes....or something
Peace
Milo is offline   Reply With Quote
Old 10-28-2004, 11:34 PM   #2
Milo's Avatar
Just as a side point I was thinking of getting a http://www.mp3car.com/store/product_...products_id=40 and a ITPS seeing as its designed for a Epia M2
Old 10-28-2004, 11:46 PM   #3
Dominik is on a distinguished road
There are many stories about how the ITPS doesnt quite fit the bill for inCar use (not without a second battery at least). I think the Carnetix regulator/shutdown controller would work well with the plug in PSU you linked to.
I'm not sure what the problem is with the Morex, but i've heard similar stories on here before... I wonder why?
Dominik is offline   Reply With Quote
Old 10-29-2004, 02:55 AM   #4
Raw Wave
Confused's Avatar
Confused is on a distinguished road
I've powered an Epia MII 10000, desktop hdd, slimline dvd/cdrw plus a USB GPS receiver and usb keyboard/optical mouse from a Morex 60W, so it's definitely not power requirements.
Does the Epia boot up if you plug it into a standard household PSU?
Avoid that "200W" PSU and the ITPS, they'll cause you more trouble than they're worth. Stick with the Morex and get yourself a Carnetix CNX-P1260, as it was designed specifically for use with the Morex PSU.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 10-29-2004, 03:58 AM   #5
Skyline is on a distinguished road
If you are after an opus
www.corrospec.com
supply New Zealand and Australia
Skyline is offline   Reply With Quote
Old 10-29-2004, 04:09 AM   #6
BigToach is on a distinguished road
just a note, if you do get that 200w snapon power supply, most of the snap-on ones dont actually snap on to the m21000 because of the pcmcia and cf card slot housings, i just got a power extender. like this one http://store.mini-box.com/ituner/atxexca.html
BigToach is offline   Reply With Quote
Old 10-29-2004, 12:44 PM   #7
justICE is on a distinguished road
You can see their should be no problem if your just running a MII1000 and a morex 60W supply (you did not specify any other hardware so I will not assume you are using any). Morex 60W supplies 1.5a constant on the 12V rail. Morex specs
The MII1000 uses only ~200mA on the 12V rail under load. Page 14 of this spec
justICE is offline   Reply With Quote
Old 10-29-2004, 06:36 PM   #8
Milo's Avatar
Thanks for all the replies
Ok so ill steer clear of the 200w thingo.
And Yes the board boots off a 250W PSU, HD ticks over even installed windows on it when the 250W psu
however when i connected it to the morex PSU HD ticks like its trying to turn over but just sits there ticking (yes i have disconnected the HD)
Im not using any other hardware other then the Morex Car kit and the EPIA board but even without the Carnetix i should still be able to boot the board, Engine on or off it dont go, I have seen the other forums where they have the same issues but with no answer why.
I called the place i bought the board and the PSU and they are telling me that 60W wont power that board and a HDD, I told em they are full of it and just dont want a RMA on there hands.
But i would like to get this going without changing PSUs so to my previous question does anyone think this should boot without a carnetix, my thought would be yes but hey my luck with this car project is going down hill
Old 10-30-2004, 10:17 AM   #9
Milo's Avatar
Well after 1 day of screwing around i found the issue, a Standard 250w AC PSU gives around 5.2V on the 5V rail and about 12.1ish on the 12V rail....
My Morex gives about 4.8V on the 5V rail and about 11.3V on the 12V Rail, I think the other board would boot because the other board didnt care it just flikered on the screen and gave dodgy sound output the MII10000 is more piccy....
Time to RMA the Morex sell it on Ebay and buy a Opus the thing that i didnt want to do :/
