Old 11-21-2004, 06:47 PM   #1
modUlarBeing's Avatar
modUlarBeing is on a distinguished road
usb hub power problem
I decided to get a usb hub to solve the problem of usb always having power with my opus 150w. I hooked up the hub and cut the red wire in the usb input to prevent the computer from powering the devices and now the computer does not see any of the devices. (yes the hub has power from an inverter)
also, I think I will move the hubs power from the inverter to the opus' 5v line if it will work....
Also do you think it might work out if I connect the hub, my external dvd drive and a wireless mouse charger? they all run on about 5v i think...
modUlarBeing is offline   Reply With Quote
Old 11-21-2004, 07:06 PM   #2
bbrother is on a distinguished road
Does the hub light up or anything, are you sure it is getting power from the inverter, try testing that. Also is it possible you could have cut the wrong wire? Give us some more details and myabe someone can help you a bit more.
EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
My Truckputer
bbrother is offline   Reply With Quote
Old 11-21-2004, 07:34 PM   #3
yes the power light works when i apply power to it after I cut the red wire which I believe is the power wire.
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 09:35 PM
Will this layout with a remote USB hub work? NoPistonPC General Hardware Discussion 14 08-21-2005 04:24 PM
New system design...power issues... lookinco Power Supplies 8 08-10-2004 04:11 PM
My experiences with various components... Defiler General Hardware Discussion 0 01-27-2004 02:49 PM
Sproggy type power good problem eugenen Power Supplies 0 08-08-2002 09:47 PM
