Old 12-07-2004, 01:05 PM   #1
RJP350Z is on a distinguished road
Question Please HELP!! PSU/ Shutdown controller questions
I have a Xenarc MP-SC1 PC and a Xenarx 700 TSV screen and am having a tough time finding the appropriate Shutdown controller or Power suppply solution for this setup. Here are my issues:
1. Xenarc PC has a DC power input (Barrel plug type) and not ATX connector on the board. The solder points are there but no connector.
2. PC has no ACPI header on the board (already confirmed with Xenarc Engineering)
First:
My theory is, I can probably pull the 12V off the OPUS ATX Connector to get the power to the board but Nat from MP3Car store said that "the OPUS is a smart power supply so it likes to “sense” how much power the motherboard is drawing so it can determine it’s state. I’m not sure how it would perform under your conditions."
Second:
Being the PC has no ACPI header can I connect the OPUS/Shutdown Controller directly to the switch on the motherboard?
What is my best solution for my issues? Do I go with an OPUS or just a shutdown controller? If just a shutdown controller is needed what i sthe best for my solution (Carnetix, Micro shutdown controller from MP3car store, other...)
RJP350Z is offline   Reply With Quote
Advertisement Sponsored links
Old 12-07-2004, 01:42 PM   #2
zootjeff is on a distinguished road
Does the 12 volts need to be regulated? To the display?
Can you provide pictures or links?
-Jeff
MPEGBOX - Plexiglass Computer
www.mpegbox.com
zootjeff is offline   Reply With Quote
Old 12-07-2004, 02:10 PM   #3
All I could find using the is "It probably does need to be regulated."
http://www.mp3car.com/vbulletin/show...ghlight=mp-sc1
Here is the link to the PC Specs
http://www.xenarc.com/product/mp-sc1.html
Monitor does not need to be regulated as per this thread:
http://www.mp3car.com/vbulletin/show...0tsv+regulated
Here is the link to the screen:
http://www.xenarc.com/product/700ts.html
Old 12-07-2004, 02:42 PM   #4
-Jeff
If the computer takes in 12 volts right from the battery and the LCD takes in 12 volts right from the battery, the uSDC20D is perfect for you. All you would need is that. From reading their marketing stuff, they are being ambiguous.
Now I can't find the specs on the PC saying if it takes in 8-15v or 12+- 5% or what the range is on the input of the PC. If you can make sure about that, then all you would have to do is wire the uSDC up to your display and computer.
-Jeff
www.mpegbox.com
Old 12-07-2004, 02:53 PM   #5
Thanks Jeff, I'll check on the specs for the PC when I get home.
Old 12-07-2004, 05:16 PM   #6
Jeff,
This is the response I just got from Xenarc engineering.
The MP-SC1 does require regulated 12V. We do sell a car adaptor for that unit.
The 700TSV doesn’t need 12V regulated supplies. It takes 10V DC ~ 24V DC
So I would be able to use the uSDC20D if I purchased the PC car adapter from Xenarc, Correct?
If not, what else would you recommend? Would Carnetix work?
Old 12-08-2004, 06:56 AM   #7
MikeH is on a distinguished road
RJP,
I believe the Xenarc PCs use a Sumicom motherboard, which has an integrated, on-board DC-DC PSU. It DOES require a REGULATED +12V supply. The CarNetix P1260 would be a perfect fit for this application.
However, from what I understand, the Sumicom mobo does not have a seperate ACPI header or input. I beleive one of my customers has soldered 2 wires across the "power" switch and attached them to a small relay, which is fed by the ACPI control signal out of the P1260. Check our forum. I think there are some details of the wiring there.
FYI....the MP3Car.com store will begin carrying the CarNetix P1260 very soon...
Good luck!
MikeH
MikeH is offline   Reply With Quote
Old 12-08-2004, 10:00 AM   #8
Mike,
Thanks, I also saw your response on Carnetix Forum.
Rob
Old 12-23-2004, 03:37 PM   #9
Finally got my Xenarc MP-SC1 running using the Canetix P1260. Works great.... Now it's time to start car install.
Frequently Asked Questions bgoodman The FAQ Emporium 33 05-03-2005 07:25 PM
Commercial shutdown controller Steinola Power Supplies 8 12-08-2004 12:30 PM
DSSC startup / shutdown controller available dashpc Power Supplies 0 04-18-2004 10:00 PM
Inverter, shutdown controller, what else?? southprk General Hardware Discussion 7 01-09-2004 06:35 PM
why use a shutdown controller??? cyjad Newbie 15 12-04-2003 05:49 AM
