The MP3car.com Store
Thread Tools Display Modes
Old 12-15-2004, 04:09 PM   #1
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Angry Power issues in 03 Mustang
Howdy,
I'm new to the carputer scene and the MP3car forums. I've been thinking about building an in-car computer and have, after years, finally resolved myself to "just do it".. but I am running into some issues in the final stages of integrating the whole project into the Mustang.
I have tried to keep the dimensions of the project as small as possible so I can fit it all into the double-din sized opening in the dash, vacated by removal of the stock Mach460 head unit: it didn't sound all that great, and it didn't have any aux in anyway.
The problems that I am running into are as follow:
a) it is not possible to power up the computer until the car has been running for a certain amount of time (varying 5-10-15 minutes), unless it was already driven in the past 2 or 3 hours. If I try to turn it on, the computer will momentarily turn on and the immediately shut off again.
b) sometimes if I roll up/down power windows completely, once the window comes to its stopping point, the computer shuts off.
Other than those issues - once it's up and running it works very well.
Here are the system specs:
- Insight Solutions P4-ITX motherboard (integrated audio, video, lan, etc)
- Intel P4 2.0GHz
- 512MB RAM
- IBM Travelstar 20GB hard drive
- Delorme Earthlink GPS
- (PW200M - 200W power supply)
- Xenarc 700TS
I learned the hard way that one of those amplifier capacitors will not solve these problems, and am now in the market for a new psu as well. Fortunately that's all that fried.
Cans someone give me some insight as to what exactly is causing the issues? I was doing some searching, and it would seem that I may need a tank circuit to resolve this...? Am I on the right track?
Has anyone else experienced these issues? Any suggestions?
TIA,
Dave
tj!2k4 is offline   Reply With Quote
Sponsored Links
Old 12-15-2004, 04:27 PM   #2
FLA
gospeed.racer's Avatar
My Photos: (0)
I dont think your power supply was doing a good enough job. Buy an Opus, once, and be done with it. It is big, but you should have plenty of room behind the stereo or nearby. They do survive a crank, and thus would also survive rolling down your windows as well
BTW, DSG is the best color they ever put on a Mustang
00 Focus LX soon to be boosted!
88 Escort GT Turbo DFI
gospeed.racer is offline   Reply With Quote
Old 12-15-2004, 05:06 PM   #3
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Thanks for your reply.. I think I'll give the Opus a shot.
However... I was just doing some more searching and found this thread, where it seems that once the weather started getting cold, it was affecting a couple of people's PSUs. In this case, it was the OPUS 150W: http://www.mp3car.com/vbulletin/show...light=opus+150
It almost sounds like the symptom of problem "a" I'm experiencing.
And you're absolutely right about the color.. it's not as much of a pita to maintain as black, but looks very classy and sharp.. in my mind, almost "undercover" Mustang lol.. and everyone who sees it likes the color as well. =)
I had a co-worker who was really into Mustangs and had a 91 LX 5.0. Now he's big into show cars and has an 00; MM&FF did an article on that car this year.
Peace!
Old 12-15-2004, 05:11 PM   #4
Raw Wave
TruckinMP3's CarPC Specs
TruckinMP3's Avatar
Vehicle: '02 suburban with quad captain seating
My Photos: (0)
That is not a common issue for people that use an OPUS or a common issue for cold and PCs in general.
You could try a diagnosing your charging system (Free at most auto parts stores).
TruckinMP3
D201GLY2, DC-DC power, 14in LCD ;) 3.5 inch SATA
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Old 12-15-2004, 05:37 PM   #5
Raw Wave
tj!2k4's Avatar
My Photos: (1)
You could try a diagnosing your charching system (Free at most auto parts stores).
I know I'm getting ahead of myself here and should get the PSU first.
My concern is just based on the fact that in that thread, one of the people experiencing problems once the cold weather started, had a late model (04) Mustang as well.
Again, I know I'm worried about something that could be a non-issue for me, but I'm curious to know what the final resolution was for that issue, just in case it does happen..
Old 12-16-2004, 05:51 AM   #6
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Alright, got the Opus 150 on order. Let's see what happens. Thanks for your insights.
Dave
Old 12-16-2004, 05:00 PM   #7
Raw Wave
TruckinMP3's Avatar
My Photos: (0)
If you are really concered, look into an upgraded alternator and voltage regulator.
The intent would be an invrease in charging potential from the alternator and a matching increase in control for the voltage regulator.
Maybe an upgraded battery as well.
again, I would suggest charging system diagnostic, it could tell you what the issue is without spending money.
TruckinMP3
Read the FAQ!
Old 12-16-2004, 05:27 PM   #8
Vehicle: 1994/Ford/Probe GT
My Photos: (0)
how are you getting power to the power supply? I sure hope you're not using the headunit's power wire from the wiring harness. You should have a direct wire to the battery (10 guage or bigger) if you don't already.
Bobby Digital is offline   Reply With Quote
Old 12-16-2004, 05:57 PM   #9
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Umm.. I would never..... aww crap. Busted.
Okay, I guess then it's really not such a great idea to use the wire harness +12v to power the contraption. I know next to nothing with regard to electricity and wiring.
I'll get my *** to Radio Shack and pick up some 10 or 12 gauge wire then and wire directly to the battery +. Is there anything I need to take into consideration other than a fuse, when wiring directly to the battery then?
Regarding the fuse: How large of a fuse would I want to use with the Opus 150W? Would I be correct in the assumption that I would require a fuse in the range of 12.5A?
Thanks..
Old 12-16-2004, 06:09 PM   #10
fasternfaster's Avatar
Vehicle: 2002 SVT Focus
My Photos: (0)
150watts / 12volts = 12.5A ... so ur good! you can use the headunit's ignition wire to control the PSU's startup/shutdown controller.
Status: 99%
hardware: 7"lilli mx440 pci,M10k/160GB/slim-slot DVD-CDRW/Hifonics ZEUS ZX8000,CNX1260,DConnex GPS,Powermate,usb WiFi
software: XP Home/Media Car/RoadRunner/IGuidance 2.0
Car: 2002 Ford Focus SVT
fasternfaster is offline   Reply With Quote
Sponsored Links
Old 12-16-2004, 06:32 PM   #11
My Photos: (0)
Thanks..
FYI the smaller the guage number the bigger the wire, ie. 8 guage wire is thicker than 10 guage. 0 guage is the thickest.
I think you should use a 15A fuse, on the battery side of the wire, within a few feet of the + terminal. Let us know if this solves your problem. Good luck.
Old 12-17-2004, 12:08 AM   #12
Raw Wave
tj!2k4's Avatar
My Photos: (1)
Thanks everyone for all your tips. You've given me some great material to work with. I'll let y'all know how it works out once I get the Opus.
Peace..
Old 12-17-2004, 03:22 PM   #13
pyros's Avatar
Vehicle: 2004 Ford Mustang Mach 1
My Photos: (0)
my problems were occurring even in the hot weather :S right now its taken a turn for the worse. I've had the fuses unplugged for days and the opus wont reset itself. I think the voltage is dropping too low during cranking and the opus goes into protection everytime.
and for the record, DSG is second to Torch Red
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
pyros is offline   Reply With Quote
Old 12-17-2004, 03:41 PM   #14
Raw Wave
tj!2k4's Avatar
My Photos: (1)
We can sit here all day and argue about the color... but Mach1 > GT.. respect!
What have you tried so far to resolve the problem?
Old 12-17-2004, 03:59 PM   #15
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
If after all those fix/change and you still have problem, check the battery.
I mean look in to more cabable battery than stock. I don't think the charging system have problem cuz the car is verymuch brand new. And car these day have very cabable alternator.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 06:10 PM
12v Power Supply at MP3Car.com store mykolJay Power Supplies 6 02-02-2006 09:17 PM
Casetronic C137 120watt power supply Change Power Supplies 2 11-13-2005 08:15 PM
86% Efficient AC-DC ATX supply auto_robotics Power Supplies 42 11-25-2004 02:16 AM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
