Old 12-22-2004, 02:54 PM   #1
120V-AC and 12V-DC together
Hi,
I have my carPC working fine with a Opus 90w. I would however like to be able to use the carPC in the house or hotel as a HTPC platform as well.
What I would like to confirm is can I use both a Morex 60w PSU (w/ standard AC-DC converter attached) and the Opus 90w 12v DC power supply together?
My plan is to:
  1. Add both PSU's to my custom enclosure
  2. Take the output going to the mobo from each PSU and combine them
  3. Send the combined line to the mobo
The system would never have input from both the Opus and the Morex at the same time. It will always be 1 or the other. Opus power in car, morex power in house.
Do you think the above will work or will I have a fried via epia
BasicEvil is offline   Reply With Quote
Old 12-22-2004, 03:26 PM   #2
HoSS's Avatar
I'm not sure thats a good idea.
It really depends on what the output circuit of each PSU looks like.
At the very least I would say fit series diodes, but i would be very careful if you try this. Use a dummy load first, instead of your mobo.
HoSS
HoSS is offline   Reply With Quote
Old 12-22-2004, 03:34 PM   #3
Since I am taking the final output (right before it connects to the mobo) wouldn't they outputs be = (same as standard ATX input to the mobo)?
I would love to simply get 2 atx extensions (1per PSU)
Remove the ends that connect to the mobo
Match all wires from both cut atx extensions and connect them 1 end that will be plugged into the mobo.
Old 12-22-2004, 03:46 PM   #4
Raw Wave
Laidback's Avatar
Why not just use an AC/DC converter to power the Opus?
Laidback
Laidback Carputer
Laidback is offline   Reply With Quote
Old 12-23-2004, 08:08 AM   #5
As simple an solution that is, it never even crossed my mind. Completed it last night working well.
Upgrading HDD tonight.
Fixed My Buzzing with AC Inverter jjcuff1 General Hardware Discussion 13 02-02-2005 09:15 PM
WTB: Morex 12V AC Adapter Dominik Classified Archive 1 10-05-2004 09:20 PM
What Gauge wires do I use? Showmehow Newbie 25 07-25-2004 10:41 AM
riddle me this - 5V or 12V DC to 100V AC inverter 666 Power Supplies 1 07-01-2004 10:26 PM
DC power supply...HELPPPPPP walid_bmw Power Supplies 3 10-02-2003 01:26 PM
