The MP3car.com Store
Thread Tools Display Modes
Old 12-27-2004, 05:08 PM   #1
vintageb3's Avatar
Vehicle: 2000/Renault/Master
My Photos: (0)
Question Problems using Ituner when vehicle is running..HELP!!!!!!
Hi Guys...
OK Christmas holidays are here...and time to get this ITX PC in my Renault van!
M-10000ITX main board
Liiliput 7” touch screen…
80 Gig 3.5” Drive
Ituner PW-120-M power supply.(Actually may be a PW-200-M…but it’s in the workshop…and I can’t remember exactly)
Everything is almost installed...or at least to the point where I can test.
It could “almost” be finished by tomorrow…if I get passed this little problem…
I had the system running in the house…in an ITX case with AC power supply.
I then stripped it out of the case…and put it bareback into the van.
It worked!...well...almost...
If I start the engine...I can't start the ITX system.
It just won't power up...
This is of course a major drawback for a mobile GPS solution
It looks like the fan actually moves a fraction….but the system won’t power up…
I have a gut feeling that it may be the fact that the board is looking for 12VDC…as is getting more voltage….after the engine is started.
I think I read something somewhere about cutting a track on the PCB…to allow for up to 16DC…but I can’t now lay my hands on this.
Anyone have a similar problem…and could point me in the right direction?
Thanks!
vintageB3
vintageb3 is offline   Reply With Quote
Sponsored Links
Old 12-27-2004, 05:15 PM   #2
My Photos: (0)
If you are getting a little more voltage than is acceptable (My brother's gets 14.4v no problem) then you could try having a diode in place to provide a .7v drop. Or 2 for 1.4v drop. Of course this affects running the pc with the engine off too... If you need it working fast, this may work tho until you figure out just how you want to proceed.
It may be that you get a 12v regulator, or a diff. psu like the opus.
ColdPhreze
14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
ColdPhreze is offline   Reply With Quote
Old 12-27-2004, 05:33 PM   #3
vintageb3's Avatar
My Photos: (0)
ColdPhreze
Hi ColdPhreze...
I did think about this...and I have diodes lying here.
I want to get this system working for the weekend...I'm on a road trip....and want to try Destanator with the speed cam POI.
I am sure that the Ituner has the option of cutting a track on the PCB...to allow for a higher voltage input...I'm just damned if I can find that info now!
I'm hoping someone else with an Ituner comes back to me...
I've heard the Opus has it's problems as well...long threads on the forum about the probs
Thanks so much for the reply!
vintageb3
Old 12-27-2004, 06:02 PM   #4
Vehicle: 1994 Ford Crown Victoria
My Photos: (0)
Not sure if this will help, and if it doesn't feel free to call me an idiot, but my system would not power up once because of a bad usb port. The fan would move a little the the whole thing would stop booting.(actually it would't even start). The usb port was allowing stupid ol me to plug in a usb cable upside down, and I'm guessing I was shorting the whole thing out.
Lucky for me I didn't fry it. Also maybe try to ground your motherboard, I know sometimes amps just won't start because of a bad ground.
ea972271 is offline   Reply With Quote
Old 12-27-2004, 07:21 PM   #5
vintageb3's Avatar
My Photos: (0)
Found that link about cutting the track on the pcb!
Don't know if it is good option for me....I'm using a 3.5" hardrive at present.
Here's the link
http://www.mini-itx.com/store/information/car_mod.pdf
Any thoughts?
Thanks!
vintageb3
Old 12-28-2004, 09:29 AM   #6
MikeH's Avatar
Vehicle: 2007 Acura RDX
My Photos: (0)
Directly from the app note:
Quote:
DO NOT USE 3.5” and regular size CDROMs with this design! Full size drives use the 12V rail for motor spinup and require a stable 12V feed. Using 2.5” laptop drives will eliminate this problem, since they use only 5V. 2.5” drives have better shock ratings, we highly recommend using such drives for vehicle designs.
This mod will most likely fry your HDD.
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
MikeH is offline   Reply With Quote
Old 12-28-2004, 09:39 AM   #7
Raw Wave
tj!2k4's Avatar
My Photos: (1)
I had a similar problem, where the PW200M wouldn't stay powered on until the engine had warmed up. I wound up frying the psu trying to resolve the issue and getting the Opus 150 as a replacement, which works perfectly.
See if after 10-15 minutes of running the car, you can power up.
Here's my original thread http://www.mp3car.com/vbulletin/show...hlight=mustang
tj!2k4 is offline   Reply With Quote
Old 12-28-2004, 04:13 PM   #8
vintageb3's Avatar
My Photos: (0)
Quote: Originally Posted by MikeH
Directly from the app note:This mod will most likely fry your HDD.
Yup...I guessed that...so I'm not going to do this...going to try diodes tomorrow...
Thanks for pointing this ou though
vintageb3
Old 12-28-2004, 04:19 PM   #9
vintageb3's Avatar
My Photos: (0)
[quote=tj!2k4]I had a similar problem, where the PW200M wouldn't stay powered on until the engine had warmed up. I wound up frying the psu trying to resolve the issue and getting the Opus 150 as a replacement, which works perfectly.
Actually...it seems to be working to a degree today...
I can power up the PC…and crank…and it survive the crank…most times…
Or if I play about long enough…I can power up after the van has been cranked…
Once it’s started…it hasn’t died yet…
Still gonna try the diodes though.
I have the PW-120-M now….going to see if I can get it to work first...before I spend anymore money…
I now have GPS problems..maybe related…but I don’t think so…
Thanks for the advice!
vintageb3
Old 12-28-2004, 06:33 PM   #10
My Photos: (0)
pw-200 is not a car PSU, even if it states "12V operation".
Look at M1-ATX (cheaper) http://www.mp3car.com/store/product_...products_id=67 or the Opus Solution PSUs. They both survive engine cranks and they can go up as 24V!
-A
[quote=vintageb3]
vintageb3
andrewb is offline   Reply With Quote
Sponsored Links
Old 01-03-2005, 05:07 PM   #11
vintageb3's Avatar
My Photos: (0)
-A
I have just ordered a ITPS....I will see how that goes...I can't get the M1-ATX here in the UK...and need to get this system "working" safely within the next week...
I will worry about an Opus later on...
vintageb3
Sponsored Links
vB code is On
Trackbacks are Off
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 09:11 PM
Hard drive shock problems. Michael Szilagyi General Hardware Discussion 8 03-21-2005 03:37 PM
fiz for running routis in 640 while keeping the ME toolbar but this is rediculous.... WhiteRabbit Media Engine 2 12-17-2004 01:27 PM
Power Problems. Please help. RPM_VR4 Power Supplies 6 12-01-2004 02:21 PM
Dell Inspiron 8200 & Lilliput TS problems? bkpsu LCD/Display 1 08-15-2004 01:55 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
