Old 01-09-2005, 08:32 PM   #1
Wire in the Opus
I was gonna wire in my opus to my puter tomorrow, but I had a couple questions.
When connecting the opus, do you connect the negative directly to th negative terminal on the battery, or can you just connect it to a ground part on the chassis.
Also when connecting the ACC part, can you just splice the ACC wire that is running to your headunit and connect both the HU and the opus to that, or do I have to run a whole new wire somewhere/somehow?
What is the recommended gauge, I hear that it should be a minimum of 8 gauge, is there like a industry standard safe default gauge?
koolaidkitten is offline   Reply With Quote
Old 01-09-2005, 08:46 PM   #2
Use any ground part on the chassis; make sure to scrape off the paint good.
For the ACC line, just splice into the one running to the radio.
8gauge is good. Go to the following link for copper wire data. There are a bunch of charts, some that tell current vs. wire gauge and length. http://www.thecarpcstore.com/link.ht...reFigures.html
The best chart for what you need is towards the bottom under the heading "Car audio cable recommendations".
ColdPhreze
14" LCD, EPIA MII-10000, 256MB, Wireless LAN, GPS, CDRW/DVD, ELM Scan,
200wRMS inverter (for the screen), CarPC Pro v2.4 Power Controller,
2 12" Pioneer Premiers, Sony 6x9s, Sony Xplode Class D mono block, Pheonix Gold A/B amp for highs
ColdPhreze is offline   Reply With Quote
Old 01-10-2005, 02:38 AM   #3
ty much for the info
extending opus wire length... kingnasty Newbie 6 10-29-2004 11:42 PM
Opus 90W power supply wire, 8 ga wire? muldrick Power Supplies 12 08-27-2004 10:27 PM
opus wont start, ign wire...? Richie Power Supplies 5 03-19-2004 10:25 AM
What gauge wire for opus? XxAndyxX Power Supplies 6 01-19-2004 11:21 PM
ignition wire for opus psu liquid_smoke Power Supplies 3 09-09-2003 10:58 PM
