Old 01-11-2005, 09:00 AM   #1
Prindle19's Avatar
Carnetix Wirring
Hey, quick question.
I plan on using 10 guage wire to connect the Carnetix to my battery, and 18 guage for the rest of my wirring, speakers, etc,
Should i put some sort of fuse in line before reaching the carnetix?
If so, what size fuse? (rating)
I plan to power my car pc, lcd monitor, and xm radio adapter(12v also) off of the carnetix.
Thanks,
Sean
Prindle19 is offline   Reply With Quote
Old 01-11-2005, 09:04 AM   #2
EBFoxbat's Avatar
25 amp fuse as close to the battery as possible. An inline fuse that's easy to change.
'04 Canyon 4x4 pickup
[---PC on hold----working on external fiberglass "tool" box---]
EBFoxbat is offline   Reply With Quote
Old 01-11-2005, 09:55 AM   #3
knubile's Avatar
The carnetix installation instructions say use a 10Amp fuse.
knubile is offline   Reply With Quote
Old 01-11-2005, 10:04 AM   #4
Prindle19's Avatar
well....10A or 25A?
Old 01-11-2005, 10:19 AM   #5
use what the instructions say (10A), this way you won't give the power supply more current than it can handle.
I would assume that the Carnetix has it's own (built-in 10A) fuse to protect it as well.
shamyday is offline   Reply With Quote
Old 01-11-2005, 10:58 AM   #6
Prindle19's Avatar
alrighty, thanks!
Old 01-11-2005, 01:10 PM   #7
10A fuse should be OK. You're really just protecting against a short in your supply wire from your battery to the P1260 with this fuse. The P1260 does have a built-in self-resetting fuse to protect its innards.
10GA wiring should be OK so long as your runs aren't outrageously long (<12ft-ish).
MikeH
MikeH is offline   Reply With Quote
Old 01-12-2005, 02:39 PM   #8
Mike,
If I get a carnetix and don't feel like installing it myself, what would you expect a random car audio installer to charge to install it?
linden_arden is offline   Reply With Quote
Old 01-12-2005, 02:42 PM   #9
Prindle19's Avatar
ran it last night, simple as can be linden. ran a 10 guage wire with a 10 a inline fuse from walmart from the battery thru a grommit in my firewall, and then hooked everything up...no worries.
Anywhere in UK to buy a carnetix? mp3oplecarrier Power Supplies 22 01-06-2005 08:29 AM
PW-70 won't boot up with Carnetix rockthevolvo Power Supplies 10 12-01-2004 07:09 PM
Casetronic C134 and opus 90w / carnetix jackjohnson24 General Hardware Discussion 4 11-15-2004 11:28 AM
Carnetix PSU 1260 60W - UK purchasers Pabs Power Supplies 21 10-02-2004 07:52 AM
carnetix cnx-p1260 djmickyg Power Supplies 17 09-15-2004 04:27 PM
