Old 01-12-2005, 08:17 PM   #1
maxxell is on a distinguished road
Temporary power question
I'm going to start building my carpc soon, but think it better to build it in the house and just install it once it's all set up and running and everything. I am going to be using an Opus (definitely) and a Xenarc (most likely), and will power the Xenarc through the Opus (using the "how to power your lilli through your opus" thing, right?)
Anyway, my question is this. How can I get the thing up and running before I actually do the install into the car? I cant just plug the opus into an outlet because it's designed for DC. Do I have to get an AC-DC converter? That seems silly. I see everyone talking about this stage a lot, but cant think of a good way around this little problem. What did you all do?
maxxell is offline   Reply With Quote
Old 01-12-2005, 08:51 PM   #2
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
car battery and a decent battery charger? should work for a while for setting up the psu etc. for installing stuff uuse a normal AC atx psu.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 01-12-2005, 10:56 PM   #3
Problem being that I only have a Dell desktop to donate to this project. I hear dell does power supplies their own way, so it wont work. Is there a cheaper plan b? I'd rather not spend the money on a new psu if it wont even be a part of the final project, seems like a waste.
Old 01-13-2005, 01:19 AM   #4
KyferEz is on a distinguished road
Pick up a spare cheap atx psu online. I find they are very handy to have around.
KyferEz
TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
PSU Wattage Calculator
Electronics Calculators
Copper Wire Data
KyferEz is offline   Reply With Quote
Question Regarding Power Antenna temposs Newbie 4 11-13-2004 08:14 PM
DC-AC Invertor power loss question doomzday Power Supplies 3 10-13-2004 01:35 PM
Power Supply/Electronics Question archimense Power Supplies 2 06-10-2004 02:43 PM
Power consumption question S4Per Power Supplies 6 02-16-2004 06:08 PM
Question about power and inverters and all that SBmp3 General Hardware Discussion 1 05-01-2003 12:35 AM
