OPUS 150 Problem FIX
I had trouble with the opus and finally found the fix.
problem i was having was that the green light would come on but the opus fan would not. It also was not powering my mobo.
If this is happening to you, you need to open up the opus case and look at the yellow coil that is right next to the 8 pin connector. This coil cannot be touching the metal case. So, try to power up the opus without the case. This should work. Now find a way to insulate the coil or case to ensure that there is no contact between the yellow coil and metal case.
People have helped me with my install so much that i thought i would share this little bit of info.
