The MP3car.com Store
Thread Tools Display Modes
Old 02-26-2005, 11:28 AM   #1
Bravellir's Avatar
Vehicle: Mitsubishi Strakar
My Photos: (0)
M1-ATX Led
hi,
I'm having problems with my M1-ATX. I tried to find out what the led means, but couldn’t find any reference to this. Except for a post by Rando stating that it should blink when only the 5v rail has power.
I connected the m1 to an epia me 6000 and when the switched connector gets power, the m1 led lights up, the board power led lights up, but nothing else appends. I measured the power at the Molex, and on the yellow I always get 0.726V and on the red always 0V.
I’m going to try right now the same setup with a regular atx power supply..
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status -->
Lilliput Installed (not indash yet..)
BraveCar 2.5
Bravellir is offline   Reply With Quote
Sponsored Links
Old 02-27-2005, 06:33 AM   #2
Bravellir's Avatar
My Photos: (0)
Just to tell that the epia works fine with a standard atx psu.
Status -->
BraveCar 2.5
Old 02-27-2005, 09:24 AM   #3
Raw Wave
rando's CarPC Specs
rando's Avatar
Vehicle: 2004 Toyota 4Runner
My Photos: (0)
Here are the possibilities I can think of.
1) Incorrect or inadequate (size) supply wires to the M1-ATX
2) Inadequate suppy - Were you using a battery or something else?
3) Short circuit -- maybe at the screw holes or the bottom side of the board?
4) Defective M1-ATX.
2004 4runner
rando is offline   Reply With Quote
Old 02-28-2005, 04:20 AM   #4
Bravellir's Avatar
My Photos: (0)
Tks Rando for the help,
1. I was using wire that is thicker than the wires mini-box supplied, but I will check with different/thicker cable.
2. For testing purposes, I had it connected to the cigarette lighter socket. Since its internal fuse is a 10A one, I guessed it won’t be a problem just to make a few tests. I will try to wire it directly to the battery.
3. I had it just sitting on top of one of those antistatic bags. But it was attached to the chassis before, on two of those motherboard stands.
Do you know what the led blinks mean? The manual ( witch I had to download btw ) don't even mention that the thing blinks.
Status -->
BraveCar 2.5
Old 02-28-2005, 08:40 AM   #5
Raw Wave
rando's CarPC Specs
rando's Avatar
My Photos: (0)
Assuming you have the older firmware, I believe the LED has 3 states.
1) OFF -- All power rails off
2) Blinking -- +5VSB power rail on, others off
3) Solid -- All power rails on.
If you have it configured HARDOFF=Never (i.e. standard ATX), then state 2 is what you'll get upon providing power to the PSU -- though it may momentary cycle all the rails once (I don't recall). After that it waits for the IGN line to go high and then after a short delay will pulse the power switch on your motherboard. Your motherboard will respond by pulling PSON (on the ATX connector) to ground. The M1-ATX will then enable all of the power rails. Once they've reached the correct voltages, the M1-ATX raises the PG (power good signal on the ATX connector). This lets the motherboard know it's ok to beging the boot process.
All of this should happen in less than 5s. Check your 2 wire connection to your motherboard power switch. Try turning it around the other way.
2004 4runner
Old 03-01-2005, 02:49 AM   #6
Bravellir's Avatar
My Photos: (0)
tks
I will try to connect the motherboard power switch both ways to see what appends.
Status -->
BraveCar 2.5
Sponsored Links
vB code is On
Trackbacks are Off
Fabrication Source Websites (LED, Plastic, Plexiglass, Fiberglass) nFiniteTuning Fabrication 21 05-03-2006 11:28 AM
Mastero MK-4 ATX PSU Semi kit for SALE Mastero Classified Archive 4 06-10-2004 01:42 PM
fs: mastero mk-3.5 120w atx dc-dc power supply infinkc Classified Archive 7 05-16-2004 06:06 PM
ATX board power?? Alphared Power Supplies 9 01-10-2003 12:36 PM
ATX and AT motherboard Beavis Power Supplies 1 05-10-2001 02:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
