Old 02-27-2005, 06:55 PM   #1
warnockm's Avatar
Control switch
I'm looking into building a switch in my center console as sort of a "control switch" or switches i should say. I would like a switch the lets you control an opus power supply to have it turn on with the ignition, turn on all the time and just be turned off. I would also like a reset switch. Has anyone wired anything like this? I'm curious what would be the best approach. Where can i get a 3 way switch for the power supply, and I'm assuming a reset switch is just a momentary switch. Also, how can i make the reset button "hidden" so i don't accidently restart the computer. Does anyone have any suggestions or ideas?
thanks!
Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
warnockm is offline   Reply With Quote
Old 03-13-2005, 11:06 AM   #2
Im looking for this too. Did you find a good thread? I had one at one time but searching for this is a pain with all the hits you get
My BMW 2004 330i
jedi7001 is offline   Reply With Quote
Old 03-13-2005, 10:25 PM   #3
I rigged a switch to my ACC line so I can make the computer think the car is off when it's on, so the computer wont boot (or will shutdown when I flip the switch off). But I haven't done anything to keep the computer running after turning off the car.
maxxell is offline   Reply With Quote
Old 03-14-2005, 12:26 AM   #4
rubicon's Avatar
M1-atx...
Well, you could theoretically run, say, CAT-5 wires (individually) to the headers on a board like the M1-ATX to control its behaviour, and wire up switches on the other end. Also, you can use a jumper to hook the PSU into the mobo's on/off switch line, and wire that up as well.
I briefly thought about doing this, but then decided it wasn't that important.
rubicon is offline   Reply With Quote
Capture GPS data at the flip of a switch Mr. Inquisitive GPS 4 02-02-2005 06:06 PM
Savage Switch Botton Group Buy via UK's Iconstyling.com.... TheBigDog General Hardware Discussion 3 07-21-2004 10:51 AM
Need clairification on wiring on/off switch syclone477 Newbie 9 03-23-2004 04:59 PM
Help With Extending Laptop Docking Station's Power Button JeffesonM General Hardware Discussion 10 04-14-2003 01:13 AM
Some sort of switch board...? claylong General Hardware Discussion 5 01-14-2003 07:17 PM
