Old 02-28-2005, 08:37 PM   #1
bobs987 is on a distinguished road
Problem with shutdown controller
Whats going on everyone, i have a uSDC20D just took it out of the box hooked up the basic connections VIN, VOUT, GND. But when i hook up the acc line the relay turns on and off, now i just searched the forums and someone said something about a relay bounce? and im guessing i need a diode between the acc line and the controller??? if so what kind?? has anyone else had this problem?
Also the pdf's talk about hooking up the 12V line from the power supply to one of the jumper pins and to use a diode for this too, but does not say which kind does any one know which one?
bobs987 is offline   Reply With Quote
Old 03-01-2005, 03:13 PM   #2
zootjeff is on a distinguished road
Can you give me a little more detail? You should be able to connect up Gnd to 0 volts, Vin to 12 volts and it should sit there and do nothing. You can then use a a penny to connect the vin connection to the ACC Lug, hold if for a second and the relay should click on and stay on. The LED should stay full on as long as you have Vin and Acc connected to 12 volts. As soon as you release the ACC line, the LED should flash and eventually the Relay should click off.
Please tell me your situation with this level of detail.
-Jeff
MPEGBOX - Plexiglass Computer
www.mpegbox.com
zootjeff is offline   Reply With Quote
High power PSU with shutdown controller lookinco Power Supplies 12 08-25-2004 01:00 AM
Shutdown Controller Questions yuprules Newbie 2 08-18-2004 02:04 PM
Mastero Shutdown Controller BigAl Power Supplies 3 08-03-2004 11:11 AM
Jeff Mucha shutdown controller, need some assitance! SLAYER6669 Power Supplies 13 02-09-2004 09:25 PM
Inverter, shutdown controller, what else?? southprk General Hardware Discussion 7 01-09-2004 06:35 PM
