Old 03-15-2005, 06:13 PM   #1
yonu is on a distinguished road
inverter wiring question
ok all here is a quick question on wiring inverters(i know not the best solution) I am plainign on using a 12awg wire with inline fuse to run the power to my inverter but my question is i want a switch int he front to turn the inverter on and off so what i am asing is do you all think i should cut the wire at the front of the car and put a switch in it or what is you guys suggestions
yonu is offline   Reply With Quote
Old 03-15-2005, 06:23 PM   #2
See me in my wet t-shirt.
stevieg's Avatar
stevieg is on a distinguished road
You can get a shutdown controller for it from the mp3car.com shop
Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
Car PC Status: Complete - Undergoing Software Redevelopment
stevieg is offline   Reply With Quote
Old 03-15-2005, 09:49 PM   #3
as stupid as this sounds i would rather not use a shutdown controler right now that is why i am asking for thoughts
Old 03-15-2005, 10:09 PM   #4
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
I don't think it's stupid.
Although I am curious as to why you wouldn't want the convenience.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 03-16-2005, 12:11 AM   #5
csnowman00's Avatar
csnowman00 is on a distinguished road
maybe you should consider what im doing....
take the power antenna wire from your head unit and put it into a relay to power the inverter...so the carputer will be on as long as your stereo is powered up
Current Progress:
[▓▓▓▓▓▓▓---]80%
Final Assembly
Ramline P3 PC
10.4 inch Touchscreen
Windows XP Embedded
Road Runner
http://www.projektnepa.com
Electrical Engineer / Mobile DJ
csnowman00 is offline   Reply With Quote
Old 03-16-2005, 05:05 AM   #6
stevieg's Avatar
OK just so we are talking on the same wavelength I didn't mean shutdown controller as in Opus,Carnetix etc - I understand you want an invertor, I meant shutdown controller for the invertor. You may have already understood what I meant, so if you did, smashing.
The circuit above is a good idea... Also you could just hook up a switch/relay combination to give power to the invertor and of course to make sure that your not running all that juice through a switch, if that worries you.
Old 03-16-2005, 09:45 AM   #7
Iatrogenic2 is on a distinguished road
I have been running mine in this configuration (switch located under my dash on 12v line before it gets to the inverter and the inverter power switch left in the on position) for a couple of years now and have had no problems. I wired it up to my accessory line so even if I froget to turn off the inverter with the switch it will still shut off when I shut off the car. Unfortunatly this has lead me to power off the pc without shutting it down leading to a long boot the next trip. To solve this I broke down and ordered a shutdown controller...cant wait till it arrives.
Hope this helps.
1997 VW Jetta GLX VR6
old HP MP
PIII 600 or so 256 MB
7" Xenarc
and some plywood holding it all together
My Project
Iatrogenic2 is offline   Reply With Quote
Old 03-16-2005, 11:17 AM   #8
thanks for all the advice i just wasn't sure if i would run into any problems simply putting a switch in
Old 03-16-2005, 11:33 PM   #9
csnowman00's Avatar
yeah a switch is good and simple, but i think automated stuff is always better.
Current Progress:
[▓▓▓▓▓▓▓---]80%
Final Assembly
Ramline P3 PC
Windows XP Embedded
Road Runner
Old 03-17-2005, 03:50 AM   #10
stevieg's Avatar
If they don't want it, they don't want it. There's no telling some people
Old 03-17-2005, 08:17 AM   #11
i am all for automation but some stuff i like to do my self what can i say
Old 03-17-2005, 11:02 PM   #12
csnowman00's Avatar
uh well
Current Progress:
[▓▓▓▓▓▓▓---]80%
Final Assembly
Ramline P3 PC
Windows XP Embedded
Road Runner
Question on Inverter draining battery when turned off PapaPrem Newbie 6 03-24-2005 12:45 PM
Wiring question pirate_king00 General Hardware Discussion 3 02-17-2005 03:01 PM
Wiring Power Switch With Inverter Jiroe Power Supplies 7 10-29-2004 06:27 PM
A newbie inverter question Cliff Power Supplies 7 03-29-2002 10:10 PM
inverter question kardas LCD/Display 0 02-26-2002 04:43 AM
