opus problems
I have two problems...which I am assuming are due to my opus 150.
My Carputer worked fine for almost a month with no problems. But now I'm having a couple of issues:
1)the opus no longer triggers the computer to turn on/off with the ignition. Worked before, but not now. I used my voltmeter to test the little two pin connector, no more 5v pulse.
2)the computer just shuts off competely after 45-60 min out of nowhere. I have to disconnect the main 12v line and reconnect it, then power on the computer and it will work again for another 45-60min period.
Can someone help me out with these problems?
I'm running it on a new car with a healthy battery, and the opus 150 has had rando's mod (kill 5v and standby) done to it from day 1.
Just seems weird that it would work fine then stop outta nowhere.
I have 4 awg wire leading to a distro block, which splits into two 8 awg wires, for my opus and amp.
