Old 04-25-2005, 10:09 AM   #1
TurboTronix's Avatar
TurboTronix is on a distinguished road
Ignition and Button on/off power
Hi,
I was wondering if there is a way to use both the ignition and a power switch to control the carputer on/off power. Basically, I know there is a way to power on the carputer when the ignition is turned on but what if I want to turn the carputer off while the ignition is still on, is there a way to do so? If so what do I need to do (maybe someone has a schematic for this type of setup).
All I want is to make my carputer turn on when the ignition is started and turn off when the ignition is turn off, and also to be able to turn the pc off or on via power switch.
Hope there is a way...
T_Tronix
TurboTronix is offline   Reply With Quote
Old 04-25-2005, 10:34 AM   #2
MikeH is on a distinguished road
Here's a way to do what you want, if you really want to turn your PC on when your ignition is OFF (note: your amps probably won't be powered if the ignition is off).
Hope this helps!
MikeH
MikeH is offline   Reply With Quote
Old 04-25-2005, 11:21 AM   #3
Well I was thinking more about having control on the computers power ON/OFF after the ingition was turned ON. I don't want to turn the pc ON if the car is not ON. Just like a regular radio, you can turn it ON/OFF after the ignition was turned ON or it can be turned ON simultaneously with the ignition (if it was ON prior to turning the ignition OFF the last time the car was running).
Thanks for the schematic, I had the same idea as well...
T_Tronix
Old 04-25-2005, 11:59 AM   #4
kungmpton is on a distinguished road
T_Tronix
You can simply mount an momentary button to your dash from power button. Nothing more is needed. Pressing it, PC will initiate shutdown. I presume your computer dont have power when ignition is off, so pressing button wont obviously turn computer on
-Kungmpton
kungmpton is offline   Reply With Quote
Old 04-25-2005, 01:02 PM   #5
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I put a switch in between my startup/shutdown controller and the ignition line. I usually leave the switch "closed" and the power flows through it to the controller. If I want to shut the PC down while the car is on, I open the switch and it appears to the controller that I've turned off the ignition. It shuts down and stays off. If I open it again, it appears that the ignition has been turned on again.
If I take the key out of the ignition, the power through that switch is gone just as if I'd opened the switch, thus the PC cannot be started or left on if the key is not in the ignition.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Powering PC With Power Button Instead of Automatic Power legend5761 Power Supplies 35 04-17-2008 11:41 AM
New product - PC Power switch with wired remote hd54321 General Hardware Discussion 5 03-08-2006 11:48 PM
ITPS reprogramming ? naruto Power Supplies 9 11-26-2004 02:19 PM
Via Epia M10000 power button LandyLuke General Hardware Discussion 5 02-15-2004 03:46 PM
Routing power button to front of PC. Can wire be too thick of gauge? LESLIEx317537 General Hardware Discussion 4 09-27-2003 03:32 PM
