Old 04-30-2005, 11:22 AM   #1
Jaz
Jaz is on a distinguished road
Car Wattage Problem
Hi all
finally got my car pc working properly with the powersource out of the car,
ive now moved it into the car.
the power source in the back, and the car pc in the front.
Now what is happening is the pc is acting like its not getting enough wattage. hard drive wont spin proplery and motherboard doesnt power up until the 2nd request. but then still wont get into xp because of the hard drive.
however this was working fine on the same power source, out of the car.
Now will this be the problem? i am running only the positive wire up the whole legth of the car... The ground for the power source is grounded in the boot, and the ground on the computers psu is grounded at the front of the car.
Will this effect the amount of wattage it can pull? if not im stuck.
Jaz is offline   Reply With Quote
Old 04-30-2005, 11:44 AM   #2
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
Need more info,
what power supply, what motherboard, what size wire did you run
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 04-30-2005, 11:45 AM   #3
evandude's Avatar
evandude is on a distinguished road
First off, WHAT is your power supply?
in my experience, the hard drive won't spin up properly when the input voltage is too low. Sounds like you are dropping a lot of voltage between your "power source" and your computer, over the long wire... why don't you put the power supply up back?
evandude is offline   Reply With Quote
Old 04-30-2005, 11:46 AM   #4
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
If it's an ITPS, it won't work properly when the car is off. Even if it's not, try starting the car, then starting the PC.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 04-30-2005, 12:51 PM   #5
Jaz
other details are irrentlivent. i just wanted to know if having different grounds points would effect wattage.
wasnt the problem, something else had changed... i was using the cigerette lighter on the jump station instead of the clamps. seems the ampage on the cigerette lighter is regulated where as on the clamps its not...
basically i have got a 2nd battery (a jump station), running a 200watt PW-200 whatever power supply.
In my house, hooked up to the battery it works fine and did for over an hour with no problems on multiple occassions.
Now i have got it in the car, same setup as in the house, and it doesnt work fine.
it worked for about 7minutes then stopped working correctly.
back to the drawing board i guess...
Old 04-30-2005, 01:00 PM   #6
ATXaccord05's Avatar
ATXaccord05 is on a distinguished road
what guage wire are you running as your power?
are you sure you have a good ground point?
test at where the 12v in/out is with a multimeter and check what your voltage is.
ATXaccord05 is offline   Reply With Quote
Old 04-30-2005, 01:08 PM   #7
Jaz
voltage was right. 12.64volts or something similar.
grounding points, one is using same as head unit, other is using a main car grounding point, which brake lights etc use.
Power cables are rated up to 17amps.
i was under the impression though that cables rated lower will still supply the current, but will be unsafe and may melt etc.
i have a feeling a 13amp cable may be used at one point.
but 13.5amps is the peak for the car psu anyway.
might just try and run a ground direct from battery to pc and try that
Old 04-30-2005, 01:24 PM   #8
Auri's Avatar
Auri is on a distinguished road
Running from the battery is so much more convenient than using an inverter. If you have an ITPS you can just set your computer to hibernate when you kill the ignition and then it will come right back to where it left off. Of course, that all assumes you have reliable power going to your machine... look into a direct battery connection - you'll never go back
BTW, I discuss all that in my book Geek My Ride, available from Amazon now. I've set up a web site if you have any questions (www.geekmyride.net).
Good luck!
-Auri
Auri is offline   Reply With Quote
Old 04-30-2005, 01:26 PM   #9
Mcnovy's Avatar
Mcnovy is on a distinguished road
use as short ground cables as possible.!
use youre chassis etc.!
test the voltage on the computer, and not on youre psu.!
you wire have som voltage drops, så the most accurate wuold be to test the voltage on the yellow cable on the harddrive.!
use minimum as thick ground cable, as youre "hot" cable.!
Sorry for the english
CarPC Specs.
Via Epia MII 12000 \\ 512 Mb Ram \\ 200 GB Western Digital \\ PCmcia asus wi-fi
Xenarc 7" Touchscreen \\ Usb Bluetooth \\ Carnetix P-1280
Mcnovy is offline   Reply With Quote
Old 04-30-2005, 01:32 PM   #10
Jaz
im not using a invertor, im using technically a battery (which is also a jump station)
I am using the chassis as a ground, and i have short cables at the moment.
Old 04-30-2005, 01:33 PM   #11
Arathranar is on a distinguished road
17A wire doesn't mean it's thick enough to avoid a large voltage drop over a long piece of wire. What gauge wire is it? What is the voltage at the computer?
Arathranar is offline   Reply With Quote
Old 04-30-2005, 01:57 PM   #12
what is your alternator rated at?
Old 04-30-2005, 02:44 PM   #13
Jaz
hasnt got a voltage drop out. 12.64volts are being delivered to the front of the car.
not sure about alternator, thats not an issue at the moment.
Old 04-30-2005, 02:51 PM   #14
So that 12.64 V is under load? I.e. with the computer connected and drawing it's 13 A?
Old 04-30-2005, 04:28 PM   #15
Jaz
well the computer doesnt seem to be working properly unfrotunatly. lol
but yes the time it did successfully boot it had that voltage.
13amps is the peak power tho, it shouldnt be pulling that all the time... hardly at all i expect. maybe at spin up, but cant see it getting to 13amps.
i dont think my setup can be any more than 150watts under load
Just for laught: Computer and Car MatrixPC Off Topic 20 01-05-2005 10:25 PM
Those of you that have used Peal N Seal... Defiler General MP3Car Discussion 35 09-22-2004 09:45 AM
Car Stereo Installation Video's for Sale johnram Classified Archive 2 09-05-2002 11:27 PM
Invertor problem - plz help! hasato Power Supplies 2 08-27-2002 12:07 AM
Annoying problem c-dawg General Hardware Discussion 1 07-22-2002 09:19 PM
