Old 05-27-2005, 10:30 PM   #1
OPUS 150 power to caputer no boot
I have had my OPus 150 in my carputer for about a year now with no major problem
Carputer:
Fic Icecube P4 mobo
celeron 2.0Ghz
512 ddr
40 gb 5200 rpm 3.5 hd
panasonic 7inch touchscreen wired to psu
no floppy usb dvd drive
usb navigation
today dove about 2 miles to get gas before going to work, turned of my car, carputer goes into standby as always. get back into my car nothing comes up. screen is on adn opus power supply fan running as is cpu fan , but no boot. Unplugged opus to reset but same result. pulled carputer out plugged in standard 150 watt atx power supply and booted with out problem. have checked all the grounds and connections and cannot find a thing wrong. my 12 volt comes in at a constant 11.97 is this too little? any suggestions?
Thanks a bunch
chirowolf is offline   Reply With Quote
Old 05-28-2005, 01:17 AM   #2
bosstone74's Avatar
curious?
BossTone74
bosstone74 is offline   Reply With Quote
Old 05-28-2005, 12:31 PM   #3
Unhappy
I'm actually having a similar problem, but on a new unit. I have a Shuttle XPC with AMD Sempron 2600. It works fine off of the shuttle PSU, but when I plug up the Opus 150, all the fans come on but the PC won't boot. I've checked the voltage and it's coming in at over 13V. I've even tried disconnecting all the peripherals. Anyone got any ideas?
Incinorator is offline   Reply With Quote
Old 05-28-2005, 01:57 PM   #4
Ok, an update. I measured the output on all the pins going to the motherboard with the Opus and with the stock Shuttle PSU. It looks like the -5V rail on the opus isn't working, which would probably explain why the PC won't boot. Guess I'm sending it back and waiting until they replace it.
Old 05-28-2005, 02:20 PM   #5
where did you test the 5V rail at one of the acc connectors? at the acc connectors I get 11.7 and 4.7. is this too low to power the system fully?
Old 05-28-2005, 09:49 PM   #6
That should be plenty according to the readings I got. I tested the voltages on the 20-pin connector on the motherboard. Here's what I got with the stock Shuttle PSU and with the Opus 150.
Shuttle:
Red = 5.16V
Yellow = 11.61V
Orange = 3.35V
Blue = -12.36V
Green = 0.20V
Gray = 4.02V
Purple = 5.07V
White = -5.06V
Opus:
Red = 5.13V
Yellow = 12.41V
Orange = 3.47V
Blue = -12.67V
Green = 0.06V
Gray = 4.29V
Purple = 4.97V
White = 0.00V
Old 05-28-2005, 10:26 PM   #7
Hmm, found this site:
ATX Connector Pinout
That said that the white wire might be no connection. It looks like the -5V might only be used on motherboards with ISA slots? Now I'm lost again as to what the problem is...
Old 05-29-2005, 09:36 PM   #8
I still have no clue whats going on with my system. I will have to call Opus on tuesday. If anyone has any ideas, stoot them my way
Old 05-31-2005, 08:27 PM   #9
we might not be in the same boat, but maybe we're in the same body of water:
http://www.mp3car.com/vbulletin/power-supplies/51160-opus120-wont-start-comp.html
Mine is brand new though, haven't had it running yet off the opus.
giddonah is offline   Reply With Quote
Old 06-17-2005, 08:39 AM   #10
Well, they found the problem. Even though the whole system only draws about 100W, it's overloading the 5V rail. The Opus 150 maxes out at 10A and my system with just processor and memory was drawing 13A, and with video card 17A. It looks like I'm just going to have to go with an inverter. Maybe I can get a pure sine wave one.
I need the p4 power cable for the opus 150 for shuttle pc! customalti05 Power Supplies 8 05-23-2005 02:31 AM
86% Efficient AC-DC ATX supply auto_robotics Power Supplies 42 11-25-2004 02:16 AM
Opus 150 and System issues septicdeath Power Supplies 9 09-16-2004 11:38 PM
Opus 90 boot time. shak General Hardware Discussion 20 09-07-2004 04:46 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 09:29 PM
