Old 06-10-2005, 05:17 AM   #1
cala is on a distinguished road
M1-ATX doesn't switch on automatically
I connected M1 cables and tried to automatically wake up my PC but it doesn't when i disconnect power switch cables from M1 and switch power manually then my PC wakes up and works perfectly. I have read trough troubleshooting section, doublechecked all cables and connections and tried again, but no luck switching again manually, pc comes up.
Tried same M1 on VIA miniITX mobo, there it worked as it must. But M1 doesn't wake up my aOpen i855GMEe-LFS Pentium M mobo
Any suggestions, what to try what to do to get automatic powerswitch working?
cala is offline   Reply With Quote
Old 07-19-2005, 04:21 AM   #2
power on delay must be lower than 200ms. i set it to 100ms and it works like a charm
Old 07-19-2005, 02:59 PM   #3
Zebelkhan's Avatar
Zebelkhan is on a distinguished road
How did you set the power on delay?
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline   Reply With Quote
Old 07-20-2005, 04:07 PM   #4
aopen mobo has that specific feature
Old 07-20-2005, 08:56 PM   #5
Zebelkhan's Avatar
can you turn on/off atx with a SPST switch? tekta Power Supplies 6 02-07-2008 06:04 AM
Capture GPS data at the flip of a switch Mr. Inquisitive GPS 4 02-02-2005 07:06 PM
Power (switch) terminals on Mini ATX board muldrick General Hardware Discussion 13 08-31-2004 02:48 AM
Need clairification on wiring on/off switch syclone477 Newbie 9 03-23-2004 05:59 PM
ATX power switch mtmsol Power Supplies 5 05-13-2001 01:22 PM
