Old 06-29-2005, 02:18 AM   #1
zootjeff is on a distinguished road
New Mpegbox Power Supply
Hey All,
Your prayers are about to be answered.
Here your looking at the new DSATX Durawatt power supply from Mpegbox.com
This power supply has the following specs:
8-16 volts in
12V @ 11 Amps
5V @ 11 Amps
3.3V @ 10 Amps
5VSB @ 1.5 Amps
-12V @ 0.15 Amps
I am going to call it a 220 watt DC-DC power supply.
Here it is powering a P4 motherboard and hard drive with an 8 volt input:
Here is the P4 motherboard on the BIOS and my Main PC on the right, it is connected to the power supply with hyper terminal:
Here is what the power supply is currently spitting out of the serial port every 100 ms:
Basically this is as follows
Temp in Degrees C : Input voltage : 12 volt rail : 5Volt rail : 3.3Volt Rail : Pot1 : Pot2 and the YYYN means all the rails are within 5% except for the input which is 7.14 volts (and powering a P4 by the way...)
This power supply is very very efficient, has a very beefy 12 volt rail, and will have by far the best serial port diagnostic and programmable shutdown controller on the market.
Any takers? :-)
-Jeff
MPEGBOX - Plexiglass Computer
www.mpegbox.com
zootjeff is offline   Reply With Quote
Old 06-29-2005, 02:35 AM   #2
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
How much are you going to be selling it for? Just asking
0l33l is offline   Reply With Quote
Old 06-29-2005, 02:37 AM   #3
Probably around $150 - $200.
www.mpegbox.com
Old 06-29-2005, 02:42 AM   #4
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
Ok......
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 06-29-2005, 03:17 AM   #5
dragonBTV is on a distinguished road
looks good!
dragonBTV is offline   Reply With Quote
Old 06-29-2005, 03:22 AM   #6
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
looks nice.. what are the dimensions?
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 06-29-2005, 03:39 AM   #7
Stealth97 is on a distinguished road
when you need some (unbiased) one to conduct real world testing and a lengthy write up, let me know
Looks very nice
Is this where the witty comment goes?
97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
Stealth97 is offline   Reply With Quote
Old 06-29-2005, 05:04 AM   #8
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
damn that thing is tiny! how the hell did you make it that small and 220W? Will it need any active cooling?
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 06-29-2005, 10:45 AM   #9
If you only use it for 100 watts you don't need a fan or anything. If your going to go over that, a fan is going to be needed. It didn't even get warm powering my 2 gig p4. It was only pulling about 90 watts in idel mode..
www.mpegbox.com
Old 06-29-2005, 12:47 PM   #10
MySQL Error
any plans to fit heatsinks etc etc?
Old 06-29-2005, 12:51 PM   #11
It has heatsinking in the board. I am going to design a case for it. That will have a 40mm Fan, it is >95% efficient. None of the parts generate more than 1.5watts of heat.
www.mpegbox.com
Old 06-29-2005, 12:52 PM   #12
MySQL Error
yeah i have been watching your 12V only dc-dc closely and was impressed by the efficiency of that.
Old 06-29-2005, 12:54 PM   #13
3.5" by 4.15"
www.mpegbox.com
Old 06-29-2005, 01:04 PM   #14
jdaniels's Avatar
jdaniels is on a distinguished road
Looks damn good, finally a ONE PIECE solution for powering bigger P4's and AMD's.
jdaniels is offline   Reply With Quote
Old 06-29-2005, 01:10 PM   #15
Raw Wave
tj!2k4's Avatar
how "tall" is the board w/ components?
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Power Supply Options? Optikal Power Supplies 9 06-26-2004 06:46 AM
350 watt power supply MasterJacko96 Power Supplies 5 01-20-2004 05:01 PM
Alright, Gonna make my own power supply. crazydemon Power Supplies 7 01-18-2004 06:36 PM
