Old 07-02-2005, 12:53 PM   #1
MySQL Error
jcdillin's Avatar
These are awesome connectors
For all of you that are wanting a way that you can create a high amperage disconnect for your DC-DC power supplies. I just redid my power supply lines with these powerpole connectors from anderson. They are great, I purchased the 45amp versions but you can get much higher amperage if you need.
I bought mine directly from anderson
you can find them here
now for some pictures of them
as you can see they slide together so you can make custom connectors, I used them to make the 5v and 12v connections diffrent in my dash so I dont plug something in the wrong way
here are my 2 opuses connected up with these connectors
So for anyone that’s looking for a great alternative to crimp connectors I highly recommend these
oh yeah and thanks to scouse for turning me on to these
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 07-02-2005, 01:15 PM   #2
MySQL Error
Scouse Monkey's Avatar
Damn good idea. Nice connectors.
:cough: http://www.mp3car.com/vbulletin/show...38&postcount=6
Don't just take JCDillins reccomendation - they are very very good. I used em on RC cars that destroyed just about any other connector
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 07-02-2005, 01:20 PM   #3
MySQL Error
jcdillin's Avatar
I knew it was in there, but it was buried deep in a thread, it neds to be out here in the open!! and we needed pictures of them in action
肚子笑痛了
S60 Install
Old 07-02-2005, 01:22 PM   #4
Raw Wave
Is there a UK supplier?
Gobby is offline   Reply With Quote
Old 07-02-2005, 01:26 PM   #5
MySQL Error
jcdillin's Avatar
Well you might check fleabay, because I was able to get a 2nd batch from there for about the same price
肚子笑痛了
S60 Install
Old 07-02-2005, 01:36 PM   #6
MySQL Error
Radio spares and Model shops (but both will not be the cheapest around). Might wanna check CPC/Farnell and Rapid electronics. Or jsut give Anderson a bell and fnd out.
Old 07-03-2005, 12:45 AM   #7
Change's Avatar
http://www.powerwerx.com also sells them.
Change is offline   Reply With Quote
Old 07-03-2005, 01:16 AM   #8
lifeboat's Avatar
I use these at work with a RigRunner as a bench test rig. Good stuff!
IEI PSB-4710, 1.5Ghz P4, 1GB RAM, 120GB HDD, Lilliput 8" TS, M2-ATX, BU-353,
Ikey SL75 keyboard, BT Mini Keyboard, WLAN, EVDO, IC-PCR100 (AM/FM/VHF), HQCT, Centrafuse 1.6...
lifeboat is offline   Reply With Quote
Old 07-03-2005, 11:06 PM   #9
PatO's Avatar
Very cool!
Do any of you know if anyone makes a through-case version of these? I'd like to have my power supply connectors plug into the case, rather than via loose wires....
(By through-case, I mean that the connector mounts to the case using screws, then the opposite connector is joined via a hole in the case.)
http://jeepmp3.home.comcast.net
CarPC Stolen. Starting over.
Ne1 recognize the avatar?
PatO is offline   Reply With Quote
Old 07-04-2005, 03:48 AM   #10
MySQL Error
If you look at the manufacturers site you will see various mounting options - one be the type of thing you are looking for.
There is also a semi-circle on each connector that forms a full circle for mounting and locking the connectors together.
Old 07-06-2005, 08:05 AM   #11
How easy are these to connect/disconnect if you compare it to a molex plug? I am looking for an easy yet sturdy connect/disconnect solution for an application that would normally use molex. A male/female barrel connector set would be awesome, but my assumption is that a barrel connector will not work as I think it's only two pole and it seems that molex uses 4 wires. But I really don't know what I'm talking about either! lol
amthar is offline   Reply With Quote
Old 07-06-2005, 09:50 AM   #12
MySQL Error
These connectors are much easier to disconnect than molex but you would need 4 connectors to replicate a 4 pin molex. And you can assemble them in any way you want (4 in a row, a square, L shape etc etc) They would be bigger than a molex but they also have a nice positive click when you connect them together - unlike molex and they wont suffer from crappy pins opening up as they are curved silver plated blades that overlap and lock together.
Old 07-06-2005, 10:07 AM   #13
evandude's Avatar
and at powerwerx the 30-amp ones are under $1 per set (one red, one black) in quantities of 10, 25, or more... and only a little bit more expensive for the 45-amp ones... those are very impressive prices to me... FINALLY I can use something much better than stupid molex connectors
But don't take it from me! here's a quote from a real, live newbie:
Quote: Originally Posted by Viscouse
I am learning buttloads just by searching on this forum. I've learned 2 big things so far: 1-it's been done before, and 2-if it hasn't, there is a way to do it.
eegeek.net
evandude is offline   Reply With Quote
Old 07-06-2005, 10:16 AM   #14
gizak's Avatar
These are great, I don't have any, but I do remember using these about 10 years ago in my RC cars hehe. Tip: if you replace all your connectors with these, you might want to make a New Connecter > Molex adapter incase you need to test hardware with other machines or vice versa.
-GiZak-
Carputer Project: 98% Complete!! *tweakin'*
Xenarc 7TSV | Opus 150 | Biostar M7NCG400 | Athlon Mobile2200 | Seagate 160Gb | Kingston 2x256mb | BT Holux GR-231 GPS | LiteOn CD-R/DVD| Keyhole Rev. Cam | Zippy Mini-glow Keyboard
gizak is offline   Reply With Quote
OEM Navigation Connectors Mr Castulucci General Hardware Discussion 14 07-22-2007 04:31 PM
what type of cables connectors are these? nutkin General Hardware Discussion 6 11-11-2004 02:38 PM
motherboard connectors adrian_uk17 Power Supplies 9 02-25-2004 09:55 AM
Question about Slimline CD connectors. Freq General Hardware Discussion 6 01-06-2004 09:25 AM
connectors cvi LCD/Display 0 03-02-2002 06:05 AM
