The MP3car.com Store
Thread Tools Search this Thread Display Modes
Old 07-05-2005, 12:48 PM   #1
wardemon666's CarPC Specs
wardemon666's Avatar
My Photos: (0)
Quick Question: Would it be bad to plug my inverter on same wire as my amplifier?
I have 4aug wire going directly from the batt down to the trunk. I am planning on using the same wire for powering my inverter. Its 2-4aug, and my amp is 800 watts max, 425 rms, inverter is 325 watts continuous...
Would it cause problems if i connect everything on the same wire? Would my puter survive crank? (it survived crank when i plugged it directly on the battery)
Thanks,
Carl
wardemon666 is offline   Reply With Quote
Sponsored Links
Old 07-05-2005, 12:56 PM   #2
anky1's Avatar
Vehicle: 2000/VW/Golf GLS 4dr 1.8t
My Photos: (0)
personally i have no problem with my setup
10ga batt to amp (210 watt)
spliced off both ground and Pos to inverter so far so good
RIP 1993 civic sedan
RIP 1993 civic Del Sol
Hello! VW Golf 1.8t
anky1 is offline   Reply With Quote
Old 07-05-2005, 01:19 PM   #3
My Photos: (0)
I don't know that I would splice off but rather run/use a distro block. for both the power and ground. In my case, I ran power and ground straight to the inverter with an inline fuse there. I then ran another set of cables from the inverter to the amp with its own connectors.
http://memimage.cardomain.net/member_images/2/web/170000-170999/170063_221.jpg
oekundar is offline   Reply With Quote
Old 07-05-2005, 03:28 PM   #4
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (130)
shouldnt cause a problem. I have a 4ga powering my inverter and 4 other things and i survive it.
Old 07-05-2005, 08:15 PM   #5
Nicorolla's Avatar
Vehicle: 94 Celica GT-V6
My Photos: (0)
it will not cause any problem if installed right
for reference check the wire section of www.bcae1.com
- carPC v2.1
Xenarc 700TSV
MSI K7GM2
Athlon XP 3200+
2x 256mb DDR333
Creative Live ! 5.1
Linksys WMP11 w/ 7db ext. antenna
Samsung 2.5" 40gig
Custom 5x10x10" window case
9A idle 12A Full load
http://www.cardomain.com/ride/852187/2
Nicorolla is offline   Reply With Quote
Old 07-05-2005, 08:21 PM   #6
anky1's Avatar
My Photos: (0)
given that is only temporary install until I get 2nd amp and glass everything... no point in buying all the stuff now before I can start wiring it right
Hello! VW Golf 1.8t
Old 07-05-2005, 09:52 PM   #7
Vehicle: 2003 Nissan Sentra SE-R Spec-V
My Photos: (0)
It will not be a problem power-wise, but some cheaper amps will let some of the electrical noise that the inverter generates into the audio signal. This was the case for the small rockford fosgate Punch 150s that I use for my center channel. A ground loop isolator fixed the problem. My Zaco AG650 was not affected at all.
Sentra CarPuter:
-InnovaTek 7" LCD touchscreen, Biostar M7VIZ w/ AMD Athlon XP-M @800 MHz 1.1V, 512 RAM, 160G HDD, M-Audio Revolution 5.1, USB Wi-Fi with custom external antenna, Holux GPS and lots of really nice audio bits...
RFMan is offline   Reply With Quote
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
inverter startup prob~! bulgogi777 Power Supplies 15 10-15-2005 02:20 PM
Question on using a relay for powering PC using remote wire mattress General Hardware Discussion 0 02-07-2005 08:19 PM
Power inverter on/off switch question Skipjacks Power Supplies 41 01-22-2005 12:33 PM
question about inverter Magsino Power Supplies 8 08-13-2004 09:09 AM
How bad exactly is an inverter? SpeedFreak03 Newbie 72 06-18-2004 03:30 PM
Sponsored Links
Ad Management by RedTyger
