Old 07-05-2005, 09:15 PM   #1
can i test the M1-ATX from anything besides a car??
i have the M1-ATX PSU and i want to test it in my house before using it in the car. nothing is working. do i need as much amps as a car battery to start the PSU or am i having a problem with the psu?
kelseymonster is offline   Reply With Quote
Old 07-05-2005, 09:37 PM   #2
Raw Wave
tj!2k4's Avatar
if you have a 12v power brick (like from a laptop) you should be able to use that to get the 12v dc. just make sure it's rated high enough to take the load of your computer.
tj!2k4 is offline   Reply With Quote
Old 07-05-2005, 10:41 PM   #3
thank you! what i was using was a very simple transformer with not enough power. the fans would just twitch instead of spin. i'll try again. thank you
Old 07-06-2005, 05:45 AM   #4
Frankino's Avatar
or you can grab a small 12v battery (lipe UPS ones), I use one of those to test and works well for half an hour
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
40gig 3.5" HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
Frankino is offline   Reply With Quote
Old 07-06-2005, 08:20 AM   #5
neon_eddy's Avatar
I used the 12v off of a standard PSU .. it needs to be connected to a motherboard to power up .. but just hook up the M1 like a drive.. worked great for me
Shawn
I jsut got an e85 conversion kit for my Audi 1.8t, it's very cool, and saves me money! e85 conversion kit
Check out my web company Minneapolis Web Designer - Himmelberger Design
neon_eddy is offline   Reply With Quote
Old 07-08-2005, 03:32 AM   #6
If you know any people who are into Amateur Radio, it's possible that they have exactly what you're looking for as far as testing is concerned. I plan on testing my car pc with my Astron VS-35M (25A continuous, linear adjustable metered power supply – weighs a ton) and doing some simulated crankings (short low voltage) and seeing how it performs. Not practical for everyone, but you never know what’s available.
-fugue
fugue is offline   Reply With Quote
Old 07-08-2005, 08:30 AM   #7
Further to Neon Eddies post, I got mine to work off a ATX psu without a motherboard.
If you short the green and black on the ATX psu, this forces the PSU to stay on. By pure luck, you can connect the 4 pin P4 connector (2 yellow + 2 black, this supplies +12v) to the ampie connector.
Seems to be working ok, as Im emailing from my SP13000/Ampie/M1-ATX/Standard PSU hybrid monster!
jasonk is offline   Reply With Quote
Car Wattage Problem Jaz Power Supplies 21 05-02-2005 04:42 PM
For Sale for all you aussies. Complete mp3 car pc Holden__V8 Classified Archive 20 04-09-2005 05:30 AM
New dc dc 90 wats psu PORTUGAL Power Supplies 8 01-06-2005 12:03 AM
How could I make the ultimate car PC powersupply and what should it do? kiddigital Power Supplies 12 12-04-2001 06:36 PM
