07-18-2005, 10:43 PM
#1
Vehicle: 2000 Pontiac SunFire
Too many fuses?
Here is what I am running
p3 1.266 cpu
full atx mobo
nvidia gforce4 mx440 agp
sblive pci sound
512 pc133 ram
1 60 gig WD 5400 rpm drive
1 20 gig WD 5400 rpm drive
1 usb linksys wifi
powering 1 system fan, not counting hsf
powering 7" vga from molex
touchscreen is using usb
Antec 250 watt psu
I am running that into a 300W inverter (Xantrex Xpower 400plus)
Also running is a 100 watt pioneer amp which has a 20 amp fuse in it.
Also DSSC startup/shutdown in the middle
Amp and inverter are running into distribution block which has two 30 amp fuses in it.
The question is, what size fuse should I put under the hood? 60 amp? The main power cable is 6 gauge and I think its max at 10 feet is 80 amps. Should I get a 60 amp inline fuse, or a 80 amp.? Should I lose the 30 amp fuses in the distro, is this too much fusing?
Im going to pick a inline for under the hood tommorow so any comments asap would be awesome!
2000 Sunfire build 100%, or is it ever really 100%?
07-18-2005, 10:49 PM
#2
Vehicle: 2002 Mitsubishi Galant
p3 1.266 cpu
full atx mobo
sblive pci sound
512 pc133 ram
1 usb linksys wifi
Antec 250 watt psu
I would definately not go with a 6ga power cable. Minimum would be 8ga. And put a 60a fuse under the hood and you will be fine.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
07-18-2005, 10:51 PM
#3
Well, I already have the 6 gauge so I am going to stick with that. I think most people run 4 gauge to their distro around here and 8 out right? Thanks tho!
I was thinking 60 amp should be fine, but I have heard of over fusing.
07-18-2005, 10:52 PM
#4
My man uses Levitra.
Vehicle: '00 Honda Accord Coupe v6
the size of the fuse should match your power draw. You don't want too large of a fuse because this is a fire hazard. For example you dont need a 20 amp fuse on a 100 watt amp, if your power cable shorts on something, about 12 amps would be shorting on something before that fuse would blow, easily causing a fire. My suggestion is if you are unsure of your power draw, get the lowest rated fuse you that you think can handle your system first. If that works without blowing, then stick with that, or even downgrade.
PC Components:
My work log
07-18-2005, 10:53 PM
#5
6 is larger then 8
PC Components:
My work log
07-18-2005, 10:54 PM
#6
Well, the 20 amp fuse is what came with the pioneer, so Im thinking it is right. What do you think about the distribution blockwith the fuses? I should have paid attention in AC/DC during college instead of drowning myself in Cisco...
Anybody wanna take a guesstimate of what the power draw of this system is? Do I count the pc and the inverter seperate?
07-18-2005, 10:56 PM
#7
distrobution block should be fine, i'd stick a 60 up front
PC Components:
My work log
07-18-2005, 10:58 PM
#8
Thats what I was thinking...
I called audio express today and they were like "relay? whats that?"
Idiots....Ive gotta pick up a extra relay for my inverter....wires galore!
07-18-2005, 10:59 PM
#9
wow, you'd think audio shops would install alarms......and most alarms require a lot of relays to hook up remote start..... thats pretty sad
PC Components:
My work log
07-18-2005, 11:00 PM
#10
Vehicle: 2002 Ford Focus
The maximum rating of the fuse should be the no higher than the rating of the cable it is protecting. You can have less if you want, just make sure that it is more than the current needed.
Keep the fuses in the distibution block and make sure that the cables supplying the amp and inverter are no thinner than 10awg. 8awg would be good.
No, this is not too much fusing. It's exactly right. The inline fuse and the fuses in the distribution block are to protect the cables and are meant to blow if the current draw exceeds the ratings of the cables (for example if they short) otherwise they will overheat and catch fire. The fuses in the components are to protect them.
07-18-2005, 11:01 PM
#11
6 is larger then 8
Yeah i know my memory went blank for a second lol....
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
07-19-2005, 07:12 AM
#12
Vehicle: 2007 Honda Fit Sport
which audio express did you call?
07-19-2005, 10:21 AM
#13
The one in Jonesboro on Highland.....
I also called another audio place on Caraway, they were idiots and didnt know if they had fuses and relays in stock.
BTW, The main power cable is 6 gauge, and the leads off of it is 10 gauge so I should be safe.
| Thread Tools |
| Display Modes |
Linear Mode
