The MP3car.com Store
Thread Tools Display Modes
Old 07-25-2005, 06:29 AM   #1
PORTUGAL's Avatar
Vehicle: 2001 VW BORA TDI
My Photos: (0)
Opus 150 -Automatic Shutdown problems
I have the Opus 150 psu, i have everything conected inside the car (12v, ground,ignition).
The problem is that the Opus acts like having no automatic shutdown, when i turn on the Key the computer doesnt boot and when its on it doesnt shutdown when i turn off the car.
The ignition wire i use is the same as my Headunit use(and it works fine with it).
Does anyone experienced anything like this ???
The only thing that helps is that if i double click my mouse the computer turn on , but the shutdown must be manual
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
PORTUGAL is offline   Reply With Quote
Sponsored Links
Old 07-25-2005, 06:52 AM   #2
My man uses Levitra.
Peoples's Avatar
Vehicle: '00 Honda Accord Coupe v6
My Photos: (0)
sounds like an issue with the motherboard pins
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 07-25-2005, 07:16 AM   #3
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
Have you checked the DIP header settings to make sure you have selected shutdown mode.
Enforcer is offline   Reply With Quote
Old 07-25-2005, 07:48 AM   #4
Tainted Love
Cris's CarPC Specs
Cris's Avatar
Vehicle: 2006 Renault Megane
My Photos: (0)
Make sure the white\green wire is hooked up to the mobo correctly.
Epia M10000
Travla C137
Opus 150W
7" MM400 V2 Touch Screen in Custom Dash
7" MM400 VGA Monitor
7" Monitors in Custom Headrests
Slim DVD
BU-303 GPS
iDrive Griffin Powermate armrest
USB Wireless LAN
Cris is offline   Reply With Quote
Old 07-25-2005, 08:23 AM   #5
PORTUGAL's Avatar
My Photos: (0)
I thought that all opus 150 had that setting as default...
How can i know the settings, opus came without instructions or manual....
I had a PDF file, but i cant seem to find it
"Make sure the white\green wire is hooked up to the mobo correctly."
I dont have it conected to the motherboard right now because if i do that i can not start the computer with the double click on the mouse....
Thanks for the quick answers
Old 07-25-2005, 08:38 AM   #6
00christian00's Avatar
Vehicle: Toyota Celica T23
My Photos: (0)
If that white\green cable is not connected it is normal that it doesn't shutdown,that is the cable that signal the mobo to shutdown the pc.
00christian00 is offline   Reply With Quote
Old 07-25-2005, 08:42 AM   #7
ste1806's Avatar
Vehicle: nissan primera
My Photos: (0)
i have the pdf manual tried to upload it in a zip file but max is 200kb and this zip is 201kb so if you want it i could mail it to you
ste1806 is offline   Reply With Quote
Old 07-25-2005, 09:28 AM   #8
PORTUGAL's Avatar
My Photos: (0)
I know that, but it didnt work with wire conected to the motherboard either, so in order to start the computer by double taping the mouse buton i had to disconect the green/white from the motherboard....
When i try to activate the automatica shutdown/startup i always conect the wire to the mobo.
ste1806 - You got Pm
Old 07-25-2005, 09:39 AM   #9
dan__wright's Avatar
Vehicle: 02 Vauxhall Corsa 1.2I - SXI Black Saphire
My Photos: (0)
try the green / white cable the other way round, its the wrong way round it wont do anything.
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
dan__wright is offline   Reply With Quote
Old 07-25-2005, 05:52 PM   #10
techy101's CarPC Specs
techy101's Avatar
Vehicle: '05/Subaru Forester XT
My Photos: (0)
http://mvaras.workisboring.com/serve...r%20Manual.pdf
Thats the Opus 150 manual
Outside the dawn is breaking on the stage that holds our final destiny...
Dual In-Dash Screen Carputer Installed Check It Out.
techy101 is offline   Reply With Quote
Sponsored Links
Old 08-06-2005, 12:46 PM   #11
Moneyfink's CarPC Specs
Moneyfink's Avatar
Vehicle: 2004 Infiniti G35 Coupe
My Photos: (93)
I have noticed this, Why is that? When i work on my carputer in my house i just short out those pins to turn it on, why does the oreintation matter.
How does it work?
My OLD carputer page
My NEW carPC
Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
Moneyfink is offline   Reply With Quote
Old 08-06-2005, 12:53 PM   #12
My Photos: (2)
How does it work?
Electricity. Positive and Negative. They have to be right. Or current will not flow. I had the same issue, just flip the connector around 180.
2003 Black Impala
Dwaine is offline   Reply With Quote
Old 08-06-2005, 01:31 PM   #13
seanz0rz's CarPC Specs
seanz0rz's Avatar
Vehicle: '98 Toyota 4Runner
My Photos: (0)
yea, i noticed this with mine too. drove me nuts.
so stupid, it really should just be a relay that closes like a momentary switch. whatever tho.
my little rule for pulling the cable out is green to the pci. opposite from what you would think, white to the pci. but its all cool.
it might be different for you depending on what mobo you have, i have the p4 870 mini itx found in the store on this site.
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline   Reply With Quote
Old 08-06-2005, 02:23 PM   #14
Moneyfink's Avatar
My Photos: (93)
I know electricity, what im saying is when i at home I just turn my mobo on by touching tweezers to each jumper. Does the opus have the current from the mobo flow trough it to turn it on or does it just short it out. Do you get what I'm asking?
My NEW carPC
Old 08-07-2005, 05:37 PM   #15
numbers's Avatar
My Photos: (0)
If so many people hadn't said that they also noticed this behavior, I'd have called BS. You're right - normally you'd expect the wires to just be shorted like a normal computer case power switch does. After taking 15 seconds to think about it, I can only conclude that the opus uses a transistor to operate the power switch. This would mean that the wires need to be connected a certain way so that the (extremely tiny amount of) current is able to flow from the mobo, through the transistor, back into the other pin on the mobo which is what powers it on. Think of a transistor as a much smaller (potentially microscopic) relay, only the catch is that current can only flow one way.
numbers is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: How to Wire an OPUS PSU Quattro The FAQ Emporium 74 08-26-2006 12:38 PM
Whats up with Geiss? Was working before but not now? PDiddy Centrafuse 7 07-01-2005 03:29 PM
Another OPUS 150 with Biostar SUCCESS! kevlar Power Supplies 1 06-07-2005 04:25 AM
Case for Biostar M7NCG 400 and OPUS 150 kevlar General Hardware Discussion 26 06-02-2005 10:58 AM
will the opus 150 power my system? I have all the figures intense Power Supplies 13 04-15-2005 02:55 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
