Carnetix P1900 Issues
Trying to get some info from people that use this PSU, I'm using it on the Commell LV-671, and I'm trying to get the system to go into standby.
The PSU is supposed to keep power going through while sending an ACPI signal to the board. (I set it to go on standby)
Well after double checking my jumpers I realized that something is up with the p1900. I'm pretty sure that the output power is supposed to be set so that it stays on even after ignition if off. Jumper JP1 shorted pins 5-6.
I'm almost 100% that my settings are correct.
Has anyone tried to do standby with the p1900?? I don't have anything plugged in to the unit other than the computer; no monitor, no usb hub... I read in the manual that if the draw was higher than 1 watt the 1900 would cut power off.
Any Suggestions??
