The MP3car.com Store
Thread Tools Display Modes
Old 08-08-2005, 06:19 PM   #1
My Photos: (0)
Shut down/Start up problem
Ok, This is my first carpc. But i know enought about electronics that I know somethings wrong here. I hooked up the carPC EZ V2.4 with my carputer last night to test it out. (its currently in a spare case i had around) just to test it. i already have the power invertor wired and all the other wires ran. i hooked everything up. i gave the accessory wire power (mimicing the car turning on) and after a few seconds the power invertor turns on, allong with the appropriate led. a few seconds later the computer turns on. a few seconds later the amps. a few seconds later the screen. but as soon as the screen gets to the user password screen, before i can type anything it says shutting down and turns the computer off, then a few seconds after its off it turns back on and just repeats forever. if i disconnect the wires that goto the motherboard power switch and hook it up to the real switch and turn the comp on manually it works fine. so it has to be the unit turning the computer off by itself, but everything else stays on fine and the car is running at 12.4 v cuz i just charged the battery and have a digital volt meter. So does anyone know why this would happen? because the whole point of the unit i paid $75 for is that it will turn the comptuer on and off. if i have to do it manually or make my own relay thing then i could have done that for the rest of the stuff too. so can anyone help me diagnos this problem?
campusmischief is offline   Reply With Quote
Sponsored Links
Old 08-09-2005, 09:53 PM   #2
pRoFiT's CarPC Specs
pRoFiT's Avatar
Vehicle: 91/chevy/S-10
My Photos: (2)
Sounds like bad wiring. I dont have an auto on off switch in my system yet but it sounds like the switch trigger is being held down the whole time. Which would turn the system on then at the password part it would shutdown and repeat. I dont know just a thought.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
pRoFiT is offline   Reply With Quote
Old 08-09-2005, 10:27 PM   #3
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (22)
Use the meter to check and see if the power on switch is being held constantly on or not by the carPC EZ.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 08-11-2005, 03:00 PM   #4
My Photos: (0)
check the output to the motherboard or the 12v switch for the startup unit. cuz the start up unit is supposed to have constant power the same as a radio would to tell it to be on. but yeah. the outpout for the car should only work for a few seconds just enough to switch it. but if it was holding it constant then the power supply would turn off after 8 seconds by itself without shutting down in windows..... it makes no sense. ill check the thing with a meter tho
Old 08-11-2005, 10:54 PM   #5
My Photos: (0)
The most likely problem is that you don't have the PC monitor wires connected (the white molex connector). If you aren't going to use that, then you must disable the PC Monitor in the configuration settings.
Edit: Anyone who has any trouble installing our hardware should submit a ticket on our website at http://carpc.kyferez.com/support/helpdesk/default.php
KyferEz
TheCarPCStore.com - Power Controllers (SDC), Inverters, Tank Circuit, GPS, OBDII, CarPCs, and more!
PSU Wattage Calculator
Electronics Calculators
Copper Wire Data
KyferEz is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Xenarc Problem or Polarity Problem? mbkowns LCD/Display 1 01-06-2007 08:57 PM
YAOP (yet another Opus problem) Frankino Power Supplies 14 06-19-2005 11:17 AM
Media Car not responding... Lilliput problem? carpcnoobie MediaCar 3 09-01-2004 01:38 PM
I got a power problem I think Rom General Hardware Discussion 14 07-16-2003 04:00 PM
cordless phone problem jstrain Off Topic 2 06-24-2003 11:09 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
