Old 10-04-2005, 07:18 PM   #1
dindin is on a distinguished road
Exclamation Help with building your own DC to DC Power Supply
I would like to have a go at building a DC -> DC atx power supply for the car computer. Does anybody have a simple guide to building one? Something that has enough wattage and that is not to hard to build. Im a bit short of cash at the moment and thought that I might learn a bit from building one also. I would like to plunge into building the car computer but would like to get the power supply side of things sorted out first.
I have found guides to making shutdown/startup controller but not the power supply.
dindin is offline   Reply With Quote
Advertisement Sponsored links
Old 10-04-2005, 08:01 PM   #2
pRoFiT's Avatar
pRoFiT will become famous soon enough
There are a lot of people here designing power supplies. Probably to sell . Unless your gifted at power supply design you would be better of buying one. Because by the time your done making one you will probably spend more then it would cost to buy one.
Although if you want to try dont listen to me. I spent about 40 bucks building a 15 amp regulator from scratch. I should probably modify it to 20 amps like i started out to build.
Make sure if you do buy one you get a good one. The pw200 is not regulated at 12volts, i had to find out the hard way.
If you do find a good schematic on building one let me know. I will spend another 100 bucks for fun. I'm so close to signing up for a power supply/electronics class at the local state college so i could design a kick *** power supply.
Anyways, good luck
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline   Reply With Quote
Old 10-05-2005, 01:45 AM   #3
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Here ya go. Mastero/Sproggy MK4.5 . It is the only easy DIY DC-DC PSU available. But, it's a PITA to get the needed parts.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Has any one had any luck converting a standard PC power supply to a DC to DC unitl? pronerd Power Supplies 14 02-11-2005 07:35 PM
AC or DC power supply w/ tablet pc? gutterslide Power Supplies 2 04-07-2004 04:12 AM
Is there any sk41g shuttle users using OPUS 150w dc to dc power supply inniss777 Power Supplies 8 11-04-2003 12:03 PM
What are the ATX DC to DC power supply options? Squeezer Power Supplies 6 07-08-2002 05:25 PM
