Old 10-25-2005, 09:14 AM   #1
Caelric's Avatar
Caelric is an unknown quantity at this point
Shuttle G5 1100h and Opus Power Supply
So, I want to get the Shuttle G5 1100h, which is a Pentium M powered Shuttle (same basic form factor as the rest of the Shuttles. Logical solution to the power supply would be the Shuttle XPC 150 watt power supply from Opus, a high quality (from everything I have read on the board) power supply.
Seems to make sense.
And then, I read more on the specs of the G5 1100h, and it appears to use a power brick style external power supply. 200 watts, so with the P-M, a 150 watt Opus would work just fine, but looking at the pictures of the connection from the external power supply to to case, it looks rather proprietary.
So, since search has turned up nothing, does anyone know anything about this, whether it is feasible or not? I would prefer to go with something that mounts inside the case, but I could easily make a mount outside the case as well, for a quality Opus supply of something along those lines.
A link to the specs for the Shuttle G5 1100h is here: http://sys.us.shuttle.com/G5_1100.aspx
Thanks for any help
Dave
2005 Infiniti G35 6MT Coupe Black/Black
Core Duo CarPC
CarDomain page
Caelric is offline   Reply With Quote
Old 10-25-2005, 09:26 AM   #2
StrataG's Avatar
StrataG is on a distinguished road
So long as the motherboard has an ATX connection, and the Opus can power your components, you shouldn't have a problem. It doesn't matter what the connection is on the stock PSU as that won't be used anyway.
StrataG is offline   Reply With Quote
Old 10-25-2005, 09:40 AM   #3
Caelric's Avatar
Well, thats the thing, I don't know if the motherboard has an ATX connection,a s it is a proprietary Shuttle motherboard. I haven't been able to figure it out from the specs on the website.
Dave
Core Duo CarPC
CarDomain page
Old 10-25-2005, 09:44 AM   #4
Caelric's Avatar
Ah, here's the specs for the MB
G5 1100 motherboard:
o Pentium M (socket 479)
o Intel 915GM + ICH6M chipset
o PCI Express Interface
o Intel Graphics Media Accelerator 900
o Sound Blaster Live! 24-bit EAX HD 7.1 channel audio
o Serial ATA
o DDR2 400/533
o Mini PCI port
Still no help there.
Dave
Core Duo CarPC
CarDomain page
Old 10-25-2005, 10:12 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
It's also known as the SD11G5. Link to manual
And no, it does not have an ATX power connector on the motherboard. It looks like a proprietary connector. They're calling it ETX.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 10-25-2005, 10:23 AM   #6
Caelric's Avatar
bah.
I wonder if the Opus power supply would put out the right power leads that I culd cut and splice.
A curse on all proprietary ****!
Thanks for the info, anyhow.
Dave
Core Duo CarPC
CarDomain page
Old 10-25-2005, 10:24 AM   #7
StrataG's Avatar
Or you could save yourself some hassle and all this research and go with a different bare-bones system
Old 10-25-2005, 10:28 AM   #8
Caelric's Avatar
Bah. It has all the features I want...except that power supply problem. Also looking at one of the Monarch Butterfly systems.
Dave
Core Duo CarPC
CarDomain page
Old 11-16-2005, 02:12 PM   #9
WiCKeD 5.9L is on a distinguished road
Would be nice, wouldn't it? I would probably go with an inverter. That is the lazyman's carPC. Too bad it has the problem like most new Shuttle cases - no PCI slots.
Audio: 4 * Rainbow Audio Germs + Infinity Basslink / Case: iStarUSA S3 / CPU: C2D T7200 / MB: MSI Fuzzy 945GM2 / SC: E-MU 1212M SC / RAM: Corsair 512MB / HD: Hitachi 7K200 2.5" 100GB / DVD: Panasonic UJ-815B / PSU: Opus 150w / LCD: 7" Xenarc
WiCKeD 5.9L is offline   Reply With Quote
Old 11-16-2005, 05:13 PM   #10
Caelric's Avatar
No, no inverter for me. Too many hassles. Anyways, I found my solution:
http://www.mp3car.com/vbulletin/general-hardware-discussion/63636-mb896-p-m-mini-itx-intel-915-chipset.html
The mini-ITX motherboard listed int hat thread, and OPUS case and power supply, and various other components, including a 2.26 GHz Pentium M.
Dave
Core Duo CarPC
CarDomain page
