Old 07-27-2001, 01:54 PM   #1
moahdib's Avatar
moahdib
Post serial port shutdown signal
Does anyone know how to send signal through the serial port to shutdown a PC running WinMe?? perhaps someone could reverse engineer the dschimdt shutdown controller which works with APC's powerchute software.
another problem I have is that winMe on my machine is not responding to power off when power button pressed. It works with standby though...anyone know why this might be? does ACPI O/S support on BIOS have to be off?
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Advertisement Sponsored links
Old 07-27-2001, 02:09 PM   #2
pinkysqueaks
Post
I believe this was on the dschimdt site. I know it's now taken down..but let me check google's cached version of the page...well...i guess he didn't say...but I'm pretty sure it's Pin 8 that you need to communicate with...as to what you need to send it...i have no idea....anyone else???
Athlon 500, 128 MB, ATI Xpert 4MB AGP TV-Out, Sound Blaster Live! Value, 8.4 GB, 2x20 Backlit LCD, Keypower 250 Watt ATX DC-DC, DSchmitd Startup/Shutdown Controller, IRMan + Backlit IR Remote, Custom Keypad, 5.6" NTSC LCD, In-Dash Slot Loading DVD, all installed in an '87 Honda Accord LX-i
pinkysqueaks is offline   Reply With Quote
Old 07-27-2001, 02:41 PM   #3
dos4who?
Post
Google's cached DSchmidt AutoOff site
and
The cached FAQ for the product
You're welcome
~m
PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
BC ROCKS!!!
dos4who? is offline   Reply With Quote
Old 07-27-2001, 03:02 PM   #4
moahdib's Avatar
moahdib
Post
they dont seem to help much still... i tried to look for info on the web but without any success =(
My TL CarPC ver2
Old 07-27-2001, 03:39 PM   #5
Registered User
marsjell
Post
I could help you, if you would permit a signal on the parallel port... the serialport is kinda hard to interface, the LPT port on the other hand is very easy, using visual basic or something like that it would be very easy...
So if you wouldn't mind using the LPT port, let me know....
If at first you don't succeed.........
destroy all evidence you tried
for info on t6369c LCD or Presslab's powersupply check:
http://www.namms.tk <=updated!!
marsjell is offline   Reply With Quote
Old 07-27-2001, 03:56 PM   #6
nester
Post
Here's a circuit for the serial port that I just happened upon...
http://www.wolfsource.org/route66/
I cheat, I own an empeg.
Meskimen's Law: There's never time to do it right, but there's always time to do it over.
http://civic.mp3car.com
nester is offline   Reply With Quote
Old 07-27-2001, 07:51 PM   #7
mpt
Registered User
mpt
Post
Itīs not a bad circuit, itīs based for Unix/linux but it think itīs easy to someone to make a simple program to send the signal trough the serial port, just has to many relays (3).
mpt
mpt is offline   Reply With Quote
Old 07-29-2001, 12:08 AM   #8
nester
Post
Quote:
Originally posted by mpt:
<STRONG>Itīs not a bad circuit, itīs based for Unix/linux but it think itīs easy to someone to make a simple program to send the signal trough the serial port, just has to many relays (3).</STRONG>
well.. it's designed to work with UPSd.. UPSd was written when there was not a UPS shutdown software for linux.. it works with APC and other ups'es. This circuit would probably work with powerchute or some other windows software.
Old 07-29-2001, 12:11 AM   #9
cenwesi is on a distinguished road
Cool
With parrallel port, i can write that code for you easily. Infact CobraII/III uses 5button control which is hooked up to the parrallel port. If you guys really want it let me know. I can even write the code to hibernate/shutdown/restart, take ur pic.
abcd-1
cenwesi is offline   Reply With Quote
Old 08-03-2001, 09:14 PM   #10
presslab
Post
You can just directly hook the +12V ACC line to the DSR, DCD, CTS, and then create a little software to shut down the computer if the DCD is low for 15 minutes. I have some VB code for shutting down, works with NT/2000 too:
Attribute VB_Name = "modShutdown"
Private Const STANDARD_RIGHTS_REQUIRED = &HF0000
Private Const READ_CONTROL = &H20000
Private Const STANDARD_RIGHTS_READ = (READ_CONTROL)
Private Const STANDARD_RIGHTS_WRITE = (READ_CONTROL)
Private Const STANDARD_RIGHTS_EXECUTE = (READ_CONTROL)
Public Enum TokenRights
TOKEN_ASSIGN_PRIMARY = &H1
TOKEN_DUPLICATE = &H2
TOKEN_IMPERSONATE = &H4
TOKEN_QUERY = &H8
TOKEN_QUERY_SOURCE = &H10
TOKEN_ADJUST_PRIVILEGES = &H20
TOKEN_ADJUST_GROUPS = &H40
TOKEN_ADJUST_DEFAULT = &H80
TOKEN_ALL_ACCESS = (STANDARD_RIGHTS_REQUIRED Or TOKEN_ASSIGN_PRIMARY Or TOKEN_DUPLICATE Or TOKEN_IMPERSONATE Or TOKEN_QUERY Or TOKEN_QUERY_SOURCE Or TOKEN_ADJUST_PRIVILEGES Or TOKEN_ADJUST_GROUPS Or TOKEN_ADJUST_DEFAULT)
TOKEN_READ = (STANDARD_RIGHTS_READ Or TOKEN_QUERY)
TOKEN_WRITE = (STANDARD_RIGHTS_WRITE Or TOKEN_ADJUST_PRIVILEGES Or TOKEN_ADJUST_GROUPS Or TOKEN_ADJUST_DEFAULT)
TOKEN_EXECUTE = (STANDARD_RIGHTS_EXECUTE)
End Enum
Public Enum PrivilegeAttributes
SE_PRIVILEGE_ENABLED_BY_DEFAULT = &H1
SE_PRIVILEGE_ENABLED = &H2
SE_PRIVILEGE_USED_FOR_ACCESS = &H80000000
End Enum
Public Enum ExitOptions
EWX_LOGOFF = 0
EWX_SHUTDOWN = 1
EWX_REBOOT = 2
EWX_FORCE = 4
End Enum
Public Enum TokenAccess
TokenUser = 1
TokenGroups = 2
TokenPrivileges = 3
TokenOwner = 4
TokenPrimaryGroup = 5
TokenDefaultDacl = 6
TokenType = 8
TokenImpersonationLevel = 9
TokenStatistics = 10
End Enum
Type LUID
lowPart As Long
HighPart As Long
End Type
Type LUID_AND_ATTRIBUTES
pLuid As LUID
Attributes As PrivilegeAttributes
End Type
Type PTOKEN_PRIVILEGES
PrivilegeCount As Long
Privileges(0) As LUID_AND_ATTRIBUTES
End Type
Private Declare Function GetCurrentProcess Lib "kernel32" () As Long
Private Declare Function OpenProcessToken Lib "advapi32" (ByVal ProcessHandle As Long, ByVal DesiredAccess As TokenRights, ByRef TokenHandle As Long) As Long
Private Declare Function LookupPrivilegeValueA Lib "advapi32" (ByVal lpSystemName As String, ByVal lpName As String, ByRef lpLuid As LUID) As Long
Private Declare Function AdjustTokenPrivileges Lib "advapi32" (ByVal TokenHandle As Long, ByVal DisableAllPrivileges As Long, ByRef NewState As PTOKEN_PRIVILEGES, ByVal BufferLength As Long, ByRef PreviousState As Long, ByRef ReturnLenght As Long) As Long
Private Declare Function AdjustTokenPrivilegesOld Lib "advapi32" Alias "AdjustTokenPrivileges" (ByVal TokenHandle As Long, ByVal DisableAllPrivileges As Long, ByRef NewState As PTOKEN_PRIVILEGES, ByVal BufferLength As Long, ByRef PreviousState As PTOKEN_PRIVILEGES, ByRef ReturnLenght As Long) As Long
Private Declare Function ExitWindowsEx Lib "user32" (ByVal uFlags As ExitOptions, ByVal dwReserved As Long) As Long
Public Function Shutdown(Operation As ExitOptions) As Long
Dim lngProcess As Long
Dim lngReturn As Long
Dim lngToken As Long
Dim udtLUID As LUID
Dim lngTokenPrivileges As TokenRights
Dim udtTokenPrivNew As PTOKEN_PRIVILEGES
lngProcess = GetCurrentProcess()
lngTokenPrivileges = TOKEN_ADJUST_PRIVILEGES
lngReturn = OpenProcessToken(lngProcess, lngTokenPrivileges, lngToken)
lngReturn = LookupPrivilegeValueA(vbNullString, "SE_SHUTDOWN_NAME", udtLUID)
udtTokenPrivNew.PrivilegeCount = 1
udtTokenPrivNew.Privileges(0).Attributes = SE_PRIVILEGE_ENABLED
udtTokenPrivNew.Privileges(0).pLuid = udtLUID
lngReturn = AdjustTokenPrivileges(lngToken, 0, udtTokenPrivNew, 0&, 0, 0&)
Shutdown = ExitWindowsEx(Operation, 0)
End Function
presslab is offline   Reply With Quote
Old 08-03-2001, 09:20 PM   #11
presslab
Post
Here is a snippet of code on the serial port side of things:
MSComm.Settings = "9600,s,8,1"
MSComm.PortOpen = True
If MSComm.PortOpen &lt;&gt; True Then MsgBox "Port failed to open"
If Not MSComm.DSRHolding Then ' data set ready low (car power is off), shut down PC when timeout occurs
shutdownCtr = shutdownCtr + 1
shutdownStatus = playing
WinAmpPause
If shutdownCtr &gt;= 5 Then
Shutdown EWX_SHUTDOWN 'shut down the computer
shutdownCtr = 0 'clear counter so we don't shutdown again
End If
End If
Old 08-03-2001, 09:46 PM   #12
DarkWolf
Post
I'm going to be developing a hardware/software system in the next month or so to do this via the game port, as well as to control WinAmp. Keep your eyes open for it.
Also, any feedback on this system, or what I could possibly control on the computer with it would be kewl. Check out my other post in this forum about it.
Scott--
97 Firebird Formula Convertable - Project R/T
Project R/T SoundDomain Page
DarkWolf is offline   Reply With Quote
Old 08-03-2001, 09:52 PM   #13
DarkWolf
Post
Opps... My bad... General Hardware forum
http://www.mp3car.com/cgi-bin/ultima...c&f=2&t=002713
