Old 08-28-2006, 02:30 PM   #16
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
& which are you doing, the p1900 or the opus?
turbocad6 is offline   Reply With Quote
Old 08-28-2006, 02:37 PM   #17
Raw Wave
Spaghetti's Avatar
Location: Spagcave, in da UK Today's phrase: J'aime Alizee
Spaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant futureSpaghetti has a brilliant future
I got the Opus 150 which I got cheap off ebay - ex emergency service I do believe. There was a huge batch of 'em and some of us UK'ers snapped 'em up for £50 each. Bargain!
In da club....
ALIZEE WANTS YOU.....
(\__/)
(")_(")
Bunny's first poo
__ U
Spaghetti is offline   Reply With Quote
Old 08-28-2006, 02:39 PM   #18
turbocad6's Avatar
cool, that's pretty cheap, hey, why do you have a + sign next to your name at the bottom of the thread/ active users area?
Old 08-28-2006, 02:40 PM   #19
Raw Wave
Spaghetti's Avatar
Huh? No idea - I don't see it!
In da club....
(\__/)
(")_(")
Bunny's first poo
__ U
Old 08-28-2006, 04:01 PM   #20
turbocad6's Avatar
on my screen I see a litle + after your name, seen it in other threads too...
Old 08-28-2006, 04:13 PM   #21
Raw Wave
Spaghetti's Avatar
I've seen it on one other person - I've wondered about it too. Still can't see it next to my name though!
In da club....
(\__/)
(")_(")
Bunny's first poo
__ U
Old 08-28-2006, 08:11 PM   #22
blessani is an unknown quantity at this point
Thats a pretty interesting way of doing this, but there are more subtle options kicking about. Just for search reference, I made a software shutdown controller for laptops http://www.mp3car.com/vbulletin/software-software-development/83060-laptop-half-arsed-shutdown-control-system.html . Its pretty comprehensive and I'm adding more by the day
'98 Peugeot 306
Project Status: I sold it ages ago!
ShutControl
The ultimate shutdown control software for laptops.
blessani is offline   Reply With Quote
Old 09-01-2006, 01:57 AM   #23
drPheta is an unknown quantity at this point
Does the Carnetix P1900 need to "sense" that the pc has turned on, like the opus does?
Quote:
now the trick here is to have the laptop "tell" the opus that it has turned on... when the power supply knows the laptop has turned on it will imediately power up all it's rails.... everything comes up & remains up for the whole cycle..
the way to have the laptop do this is to tap into a usb cable plugged into the laptop... just open up a cable between the laptop & the usb hub... inside all the insulation & ground shield you should find 4 wires.... red, black, green & white....
the black & the red are 5v - & +... these should be tapped & extended out of the harness... then carefully re-wrap & replace sheilding at the splice.... a thin strip of tin foil wrapped to connect the interupted shield does the job here...
this red & black from the usb of the laptop should now be used to trip a 5v relay... this will power up as soon as the laptop responds to the "on pulse" from the opus & turns on..... this relay should be used to connect a ground from the opus togeather with a green wire that is at the main atx mb connection from the opus.... this green wire going to ground is what tells the power supply that the system has powered up... causing the power supply to fully power up.... walla..... done...... simple & effective....
drPheta is offline   Reply With Quote
Old 09-01-2006, 02:18 AM   #24
turbocad6's Avatar
for sure..
& blesani, software may be more subtle, but hardware is more reliable I think...
not to take anything away from your awsome program, don't get me wrong, but a startup/shutdown controller directly wired has to be a more solid solution I would think...
Old 06-25-2009, 07:31 AM   #25
amowolves is on a distinguished road
Hi Newbie here sorry for the dumb question but will theis relay work for the usb to opus trickery?
http://www.maplin.co.uk/Module.aspx?ModuleNo=37525
also how do i wire a relay up? i.e how do i know which pins the four wires connect to?
amowolves is offline   Reply With Quote
Laptop for carputer project airborne_cookie Newbie 13 05-31-2005 11:23 AM
Put laptop drive in dash? eblend General Hardware Discussion 2 04-30-2005 03:55 PM
OPUS wiring question Slitha Power Supplies 1 01-11-2005 03:47 PM
86% Efficient AC-DC ATX supply auto_robotics Power Supplies 42 11-25-2004 03:16 AM
Anyone put an Opus inside the case? lbk Power Supplies 4 08-28-2004 11:18 AM
