I have a slotload DVD drive in the dash, which is powered from the mobo's FDD connector, connected to the pc via an IDE to USB2 adapter cable, which in turn runs to a powered USB2 hub.
When I connect the hub to the pc, it registers as a USB2 device. However, when I add in a 3m USB extension lead, it registers as a USB1.1 device
I've put a DVM to the hub and the usb cables and they all register 12v and 5v respectively.
aren't the cables the same anyhow? I had the same problem... didn't really resolve it but I redid my system and made the DVD drive IDE (moved mainboard closer). Just curious but is it a Panasonic drive?
Panasonic CW-8124-B
a 5m USB2 extender lead knocks out about £3 from my local supplier so worthwhile purchasing to see if it eliminates the problem...
