Old 11-08-2005, 04:30 PM   #1
pip
pip's Avatar
Electrical moron needs some help before he burns the car to the ground.....
I added a DPDT switch between the power & acc and my opus 150 so I can control whether the PC starts up or not. Throw it one way and the PC starts with the ignition. Leave it in the middle (off) position & it wont start up, throw it the other way & starts up immediately. This was documented before & I got it working correctly.
Now I want to insert another switch in the power line before the above switch so I can turn off the power completely to be certain the PC can't drain the battery. I got a SPST illuminated rocker switch to turn on/off the power & have a red light showing power is on.
The diagram on the back looks like the attached diagram:
I have a 12V line going in and want to have a 12v line going out that is switched....and I want the power light on when power is on. My first attempt at this meted the plastic off my test earth wire with great rapidity. I guess an earth is not correct
How do I wire this up? I could use the help as it seems I'm an electrical retard
pip is offline   Reply With Quote
Old 11-09-2005, 10:24 AM   #2
pip
pip's Avatar
Anyone?
Old 11-09-2005, 10:32 AM   #3
BoraXP's Avatar
is it an A/C switch?
BoraXP is offline   Reply With Quote
Old 11-09-2005, 10:46 AM   #4
pip
pip's Avatar
AH, yes it is. Can it still be used?
Old 11-09-2005, 11:03 AM   #5
BoraXP's Avatar
no not really
find a 12v swtich with a led
Old 11-09-2005, 11:53 AM   #6
MySQL Error
MatrixPC's Avatar
You need an ON-OFF-ON switch.
Something like these
http://www.radioshack.com/product/in...entPage=search
Top pin connect to battery +
Middle Pin connect to Opus's ACC/IGN (or triggle wire).
Bottom pin connect to car's ACC/IGN wire.
Operation:
Push top ON - instant on without key inserted.
Center - OFF
Push bottom On - On with key in correct possition (ACC/IGN).
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 11-09-2005, 11:56 AM   #7
pip
pip's Avatar
OK, thanks. I have another switch I can use. Doesn't light up, but it'll work.
Old 11-09-2005, 11:59 AM   #8
kbyrd's Avatar
Be sure the switch is rated to handle the ammount of current (amps) that you intend to run thru it. I just learned this a week or two ago on this forum (thanks for greenman100).
I couldn't find a small enough switch (physical size) that handled the current I wanted. So I installed a relay. The switch is inline with the relay's control contacts while the PC is powered off the relays switched contacts.
In the service of a vengeful God.
My worklog.
Status: First carPC installed, uninstall, and selling off parts soon.
kbyrd is offline   Reply With Quote
Old 11-09-2005, 04:11 PM   #9
pip
pip's Avatar
Thanks all, working just fine now
FAQ: Connecting your Car PC's Power and Speakers da_kooz The FAQ Emporium 40 05-19-2007 08:50 PM
The quest for no noise mp31500 General Hardware Discussion 26 04-02-2007 10:12 PM
power problems while car is running.. TimW General Hardware Discussion 28 03-18-2006 09:11 PM
Employee Discounted Cars: Flatout BIG LIE! sdashiki Off Topic 33 10-31-2005 05:53 PM
Alpine / PC Challenges all around... acitrano General Hardware Discussion 5 11-10-2000 07:45 AM
