The MP3car.com Store
Thread Tools Display Modes
Old 12-08-2005, 10:39 PM   #1
Vehicle: 2003 BMW 318Ci M Sport
My Photos: (0)
Powering your OPUS out of the car the cheap way with ATX PSU
After hours of searching these forums and Google Groups I have just mastered how to power my OPUS when I take my CarPC out of the car and into the house - so I'm just letting everyone else who doesn't know, now know aswell. This is for those that use a DC-DC power supply but don't want to disconnect all the connectors inside their CarPC and reconnect them to a standard PSU as this is a big pain in the arse. This method uses a cheap standard ATX PSU to act as your car battery. This has been discussed before but I could never find a step-by-step method. So here it is.
STEP 1
Basically, buy a cheap standard ATX type PSU for around £5 ($10) from your local PC supplier shop. Make sure it's around 300Watt and can supply at least 15Amps at 12Volts on the 12V rail (it will have a sticker on the side of it saying the output Amps for the 12V rail). This PSU will now be your car battery when your in the house. You will obviously also need to supply mains power to this using a standard power lead.
STEP 2
As we have an ATX power supply and we're not using a motherboard we need to short a connection to make it turn on. The green wire (sometimes grey on Dell PCs) coming from the PSU should lead to the ATX motherboard connector (Pin 14). Short this with any black wire (there is one next to it) with a piece of wire to allow the PSU to turn on. Enure it does turn on (by listening to the fan rotate) before continuing. The method I used is here: http://modtown.co.uk/mt/article2.php?id=psumod
STEP 3
All the yellow wires coming out of the PSU are 12V - which is what we need (same as car battery). Cut all the yellow wires (just the yellow wires at the moment) at their connector ends leaving a bit of length to each wire. You should typically have 5 wires (maybe more). The yellow wires will typically be wired to all kinds of connectors. Don't worry, cut them all.
These yellow wires are the positive terminal of your house car battery.
STEP 4
Now do the same with any 4 of the black wires coming from the PSU (Obviously execpt the one you just used to short the green wire). HOWEVER, leave at least one molex connector with a red and the black wires intact. So one of your connectors will now have RED / BLACK/ BLACK / [cut off yellow] . This will be used later.
These black wires are the negative terminal of your house car battery.
STEP 5
Strip all the wires you just cut (yellow and black) and twist the bare metal ends neatly. Now take all the yellow wires ends EXCEPT ONE and twist them together to make one big wire. Do the same with ALL the loose cut black wires.
You should now have a bunch of yellow wires all twisted together, a bunch of blck all twisted together and a single yellow wire on its own. You should also have at least one molex connector with two connected black wires and a red wire going to it.
STEP 6
Connect the bunch of yellow wires to the positive inputs of the OPUS. I have the OPUS 120W which means I have two yellow input wires for positive. All these need to be connected up. How you connect these is up to you. You can simply twist them together and tape them or attach connectors. Twisting together and taping is cheaper but less convenient.
Do the same with the bunch of black wires and the negative input (2 black wires on my OPUS 120W).
STEP 7 (THE IMPORTANT ONE)
This is the part that finally got my setup working. After hours of searching I found that a small load has to connected to the 5V rail of the PSU in order for it to function properly. This is why we left a loose molex connector in STEP 4. Plug this loose molex into any device that runs on the 5V rail. I'm using an old CD-Drive. You could use an old floppy drive or other device instead (note: the floppy doesn't use a standard molex connector for power). EDIT: Also (which I have now done), you can wire up a fan to the 5v rail as these are really cheap. Even if the fan is a 12v fan it will still work on the 5v rail and pull off enough current.
STEP 8 (ALSO IMPORTANT)
Now the remote feed has to be applied to your system. This is why we left the single yellow wire out in STEP 5. This is your remote feed. On my OPUS 120W, the remote feed is a red wire.
IMPORTANT: Turn on your PSU and WAIT (I mean it!!) for your OPUS to FLASH AT LEAST TWICE before connecting the remote feed up. As soon as you apply the remote feed, the PC should boot perfectly.
That's it. This is by no means a perfect solution - but it does work and it is cheap. The important things to remember is that you MUST have that old device connected to take a load from the 5V PSU rail and you MUST wait for 2 flashes from the OPUS. Of course, using the old atyle AT PSUs don't have these problems.
Hope this helps in some way!
LLOYDY
lloydy is offline   Reply With Quote
Sponsored Links
Old 12-08-2005, 11:07 PM   #2
Vehicle: 04/Acura/TL/6MT
My Photos: (0)
LLOYDY
Or the one step method:
Buy one of these:
http://www.mpegbox.com/atxBreakout/index.html
MPEGBOX - Plexiglass Computer
www.mpegbox.com
zootjeff is offline   Reply With Quote
Old 12-08-2005, 11:34 PM   #3
My Photos: (0)
How much are they? This looks pretty good. If this came with a connector to go straight into the OPUS it would be perfect.
However, I was going for more the "power with stuff your likely to have around the house" method.
LLOYDY
Old 12-08-2005, 11:49 PM   #4
pRoFiT's CarPC Specs
pRoFiT's Avatar
Vehicle: 91/chevy/S-10
My Photos: (2)
Added help. A 3 prong car power connector that you can buy at the local car shop makes an easy way to connect and disconnect your carputer from the car and in house power supply. With a simple on off switch for the remote line. And as everyone knows put a fuse on the power lines.
To keep it clean you could completly open up the atx power supply and remove all the unused wires from the circuit board. And with a high wattage resistor you could load the 5volt line without the use of a floppy or cdrom.
This line is a space saver so i can add to later
oh delete the double post
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
pRoFiT is offline   Reply With Quote
Old 12-09-2005, 02:19 AM   #5
yamathegreat's Avatar
Vehicle: 1994 ford explorer xlt
My Photos: (0)
thanx for the info guys!
3 questions
1) why does this need a 5v load?
2)what are the stats of a resistor that would emulate a 5v load?
3) what happens if their is no 5v load
yamathegreat is offline   Reply With Quote
Old 12-09-2005, 08:15 PM   #6
nitropwd's Avatar
Vehicle: 96, Chevy Cavalier ; 2004 Acura TL
My Photos: (0)
sounds like a damn good product, anyway to purchase one?
I've looked on the site and didnt find much information.
Motherboard: M10k
Power: M2-ATX
Storage: 200gb 3.5"
Optical: Slim Slot cdrw/dvd (USB Enclosure)
Audio: SB Audigy
GPS: BU-353 & iGuidance 4
OS: Win FLP (Fundamentals)
Software: Roadrunner (Lucid Skin)
nitropwd is offline   Reply With Quote
Old 12-10-2005, 12:23 AM   #7
My Photos: (0)
I don't know what to charge for it? What is the range people would pay for it?
The problem right now is I've only built 5, the raw board is 13 bucks. If I built 100, it could cost maybe 15-20 bucks..
www.mpegbox.com
Old 12-10-2005, 12:39 AM   #8
kirbycope's Avatar
Vehicle: 2007 Chevy Aveo Hatchback
My Photos: (0)
If you want to be nice parts + labor or charge double that to make profits. Lbor pricing depends on how long it takes and how much you thing your time is worth.
Post Whore's tip:
User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/showthread.php?t=65044
kirbycope is offline   Reply With Quote
Old 12-10-2005, 03:23 AM   #9
My Photos: (0)
Thats the problem with a product like this, If it costs 20 bucks, people might rather hack up there ATX power supply that costs 5 at a garage sale rather than to bother.
www.mpegbox.com
Old 12-10-2005, 03:49 AM   #10
pRoFiT's Avatar
My Photos: (2)
Yah most people on this site would probably build there own. Although it would be nice to have for testing power supplies say for a computer shop. Or if you have a nice 450 watt power supply and you dont want to cut the wires off of it. 20 shipped i might buy one
Sponsored Links
Old 01-02-2006, 11:16 AM   #11
shrinkydinx's Avatar
My Photos: (0)
why must i wait? just wondering...
shrinkydinx is offline   Reply With Quote
Old 01-04-2006, 12:12 PM   #12
randomjohn's Avatar
Vehicle: 2003 Jetta 1.8T
My Photos: (0)
except replace "might" with "would"
GA-K8VM800M, Sempron 64 2800+, 512mb DDR400, D-Link USB BT, Linksys .11g NIC, 250gb IDE, BU-353, SIR-ALP1 w/ MJS, DSATX 220w, DWW-700H
Worklog: http://www.mp3car.com/vbulletin/showthread.php?t=65059
Now with pictures!
randomjohn is offline   Reply With Quote
Old 02-12-2006, 03:01 PM   #13
My Photos: (0)
I'm not sure why exactly. I think the OPUS needs at least 10 seconds of haveing power going to it (one flash of the LED) before the remote line will turn it on. In other words, you cannot just have all wires connected (ground, 12v, remote) and expect the PC to boot just by switching the PSU on and off - You have to wait, then apply the remote feed.
LLOYDY
Old 02-16-2006, 05:05 AM   #14
ramy_zohair's CarPC Specs
ramy_zohair's Avatar
Vehicle: 2002 Mitsubishi Magna
My Photos: (0)
nice write-up. i guess its the same for the M1/M2-ATX.
Final Touches
Car: 2002 Mitsubishi Magna EI
CarPC: SP13000, M2-ATX, 512 MB RAM, 120 GB 2.5" HD, X-Fi Sound Card, Xenarc 700TSV, Garmin 18 USB.
Audio: 2X15" Rockford Punch Z, 1 Rockford Punch 2-ch Amp, 1 Soundstream Lil Wonder II 4-ch Amp
ramy_zohair is offline   Reply With Quote
Old 02-16-2006, 12:06 PM   #15
My Photos: (0)
Yes I think it is. All the PC PSU is doing is acting as a car battery - a really cheap one!
LLOYDY
Sponsored Links
vB code is On
Trackbacks are Off
Computer PSU (AC) to Power Opus Jcarere Power Supplies 5 11-17-2005 06:44 PM
Does CNX 140W PSU support standby/hibernate as OPUS 150W PSU does? baboojoon General Hardware Discussion 1 07-07-2005 11:27 PM
opus somewhat powering on? Rudsky Power Supplies 4 02-17-2005 12:05 PM
New dc dc 90 wats psu PORTUGAL Power Supplies 8 01-06-2005 12:03 AM
can I power a car stereo with an ATX PSU? Fourgig General Hardware Discussion 9 10-03-2001 08:53 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
