hi
open the xbox up ... run a ground to the outside of the rca outputs on the xbox!! then ground it to the car in differnt places ..
or
run a ground to the outside of the rca outputs on the xbox,
then take that ground out side the case where the 2pin power cable is.. put a bullet conector on it ... then from the xbox plug (that u are plugin in to the inverter) take a cable from the earth (top pin) down the ac cable with a female bullet .. conect it to the male bullet comin out of the xbox, try that!
Head unit - Pioneer - DEH-P6400R
Speakers - componant sets up front, 2x mutant 2way in rear.
Amps - 2x 500w
Subs - 2x 12" 500w 50oz
90% dun.. need screen :~
