I just wanna check in to make sure I've got it all right and that the battery power output is at fault, and not my wiring.
Ok, running from my solenoid/starter relay to my inverter is 8 gauge wire at about 8 foot with a 40 amp fuse 1 foot from the solenoid. On the solenoid and inverter terminals I have ring connectors made for smaller than 8 gauge wiring. (I had to rig them to fit the wire) When sitting in park after about 3 minutes my inverter overloads, (obviously due to low voltage from battery) but when driving it works fine and I have no problems whatsoever. When measuring the voltage of the wiring at the inverter to the ground (car chassis) while the car is sitting still I get 12.65 Volts steady. When driving with voltmeter plugged into the inverter it reports around 110 volts.
My questions are:
- Should I be getting 13.8 volts at the inverter?
- Should I be getting 120 volts output from the inverter?
- Is it safe to be running smaller terminal connectors, or should I go out and buy the high priced gold plated rings from Radio-Shack that are made for 8 gauge wire?
If anyone here has an inverter and has any useful info, please throw it in. I need as much as I can get.
I'd answer some of these questions myself, but my multimeter died.
Thanks in advance!
