The MP3car.com Store
Thread Tools Display Modes
Old 02-11-2006, 06:05 PM   #1
DaveB's Avatar
Vehicle: 2004 Dodge Ram 2500 4x4 Quad Cab Turbo Diesel
My Photos: (0)
M2-ATX Switched ignition wire?
Does anyone KNOW FOR CERTAIN if the switched ignition wire on the M2-ATX is for signaling only, and that the constant 12 volt wire actually carries all of the power?
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
DaveB is offline   Reply With Quote
Sponsored Links
Old 02-11-2006, 06:08 PM   #2
RawsonDR's Avatar
Vehicle: '98 Toyota Avalon
My Photos: (0)
I'd also like to know.
RawsonDR is offline   Reply With Quote
Old 02-11-2006, 08:17 PM   #3
DaveB's Avatar
My Photos: (0)
Bump.
Come on guys....someone must know the answer!
I'm wiring right now and I need to know the answer to this question so that I know how many amps to plan for on the switched ignition wire. I have 10 guage from the battery for constant 12 volt. If the switched ignition is just for signaling, then it doesn't matter how big the wire for it is or how many amps it will carry. Heck, I could tie in to the lead on one of the cigarette lighters that is only hot when the key is on. But I can't do that if the M2 might take as much as 15 amps on the switched ignition lead.
8" Lilli TS
MB896F Mini-ITX MB
1GB SDRAM DDR2 533
3COM BKP Cam
Old 02-11-2006, 11:04 PM   #4
My Photos: (0)
The switched 12V wire is just a sensor. It ends up in the microcontroller, draws only 1mA.
-Andrei
Quote: Originally Posted by DaveB
Bump.
andrewb is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
In search of an ignition wire witten Power Supplies 16 07-27-2006 01:29 AM
ignition wire for opus psu liquid_smoke Power Supplies 3 09-09-2003 10:58 PM
Interesting problem trying to extend ATX switch InFix General Hardware Discussion 17 12-21-2002 02:52 PM
Instruction For Atx Shutdown! Mastero Power Supplies 1 10-17-2002 02:44 PM
ATX and AT motherboard Beavis Power Supplies 1 05-10-2001 02:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
