Go Back   MP3Car.com > Mp3Car Technical Hardware > Power Supplies
Old 02-16-2006, 01:30 PM   #1
Genesisfactor is on a distinguished road
Power strip calculation question
I need to know what the electrical calculations applied to a power strip are. I'm using a 2 port 400W (800W peak) inverter and have 5 devices that require regulated power. I'm just trying to figure out if i can connect all the power to one port or and how much do i have to spare, if its safe, and if i need more than one port, what is the maximum amount of ports i can use? Sounds like an electical engineering test question, doens't it? Sucsk for me, but i'm mechanical
I know DC-DC is great and all, but i'm using a laptop and would rather not mess with things right now as this is my first carputer. This may not be the most "integrated" way, and therefore not the best, but its a second best way and works for me for now.
Thanks!
Carputer Progress: Here we go again...
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Join the fight against carputters. EMAIL ME!
Genesisfactor is offline   Reply With Quote
Old 02-16-2006, 01:48 PM   #2
Neither darque nor pervert
DarquePervert's Avatar
Lifetime bans: 981
Bans this month: 0
DarquePervert is a name known to allDarquePervert is a name known to allDarquePervert is a name known to allDarquePervert is a name known to allDarquePervert is a name known to allDarquePervert is a name known to all
Have you considered a car adapter for your laptop? It's more efficient than an inverter and won't require you to modify the laptop in any way.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 02-16-2006, 04:26 PM   #3
monger's Avatar
monger is on a distinguished road
Thanks!
The number of ports on the power strip dosent matter. Just so long as the total wattage of the combined devices dosent excede the rating of the power strip or the base load rating of the inverter.
Think of it this way, you could have a 100 port power strip full of devices each using 1 watt of power ( totaling 100 Watts draw) and be perfectly fine. Aside from the rats nest of wiring
Monger
ICQ-7207702
UPDATE: I moved farther north. Now its even too cold for the deer; only moose now
monger is offline   Reply With Quote
Old 02-16-2006, 11:47 PM   #4
hehe, i like rats...jk
Thanks. I remembered that there was an amperage concern though back in my highschool physcis class, where if you exceeded the amperage, you tripped the circuit breaker. I wanted to know those calcs. Thank you for yoru help. I know i'm pushing about 210 Watts and maybe about 15-17 amps.
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 02-16-2006, 11:55 PM   #5
nkotch's Avatar
nkotch is on a distinguished road
Check the manual for the inverter and see if it says anything about if each outlet is separately fused or not. I really doubt it and agree with monger....just worry about the total power draw....2nd outlet is really just for convenience.
But do a google search for "power calculator" or "wattage calculator" or just look up the specs (wattage, amp draw) for each piece of equipment you'll plug in and just compare it to what the inverter will handle....no real calculations involved.
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
nkotch is offline   Reply With Quote
Old 02-17-2006, 05:24 AM   #6
Rocky388 is on a distinguished road
Well, your inverter is good for around 30 amps (400 watts / 13.8 volts)
So if all the devices added together that you wanna plug in are drawing 15-17 amps, you still have 13-15 amps to spare.
Take 2 - '03 Audi A4
macmini with an 8" widescreen (in progress)
My 2004 Ford Ranger:
14" LCD w/ custom made aluminum bezel
Completly custom computer case
status: Totaled
Rocky388 is offline   Reply With Quote
Old 02-18-2006, 09:38 PM   #7
THe inverter syas 3.7 amps...go figure. I thought it woudl be like your calc, rocky.
DP, sorry, i didn't read your post ;ast time. I am powering quite a few items. Also, i want my cigarrette lighter free for some of my devices (air pump, cell phone charger, heat based torture device to keep my little brother in line). Beleive me, its going to good use . Besides, i alread shelled out for the inverter...and an SDC. why not use it?
Seeign that there's no problems, i need to figure out what stri i shoudl get as some of these have thsoe annoyingly huge adatpers. Thanks guys, i'm happy. God bless and have a great one!
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 02-19-2006, 09:23 AM   #8
cMags's Avatar
cMags is on a distinguished road
The calculation is WATTS = VOLTS x AMPS. So you're going to have different amounts of current on either side of the inverter in order to have the same amount of power. Your inverter is pulling around 30A into it from the battery (400W/13.8V), but is outputting ~110V, so is only putting out about 3.7A like it says (400W/110V).
cMags is offline   Reply With Quote
Old 02-19-2006, 03:59 PM   #9
so no go for the 15 amp thing?
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 02-22-2006, 12:30 PM   #10
Seriously though, are you saying i can't run more than 3 devices oon this hting becuase of the amperage requirments?
THese are the amps it pulls
2.4- axim
1.5- NX
4.5-laptop
2.4- DVD
1.4- usb multiport hub
maybe 1 or two for the NVD
Like i said, the wattage doesn't excced 200W. By what you're saying, i'm no where near the safe zone and won't even be able to power the laptop since it excceds the amperage of the inverter. AM i missing something or am i good to go?
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
Old 02-22-2006, 03:58 PM   #11
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Something isn't correct here.
So you use a laptop, take a look at the power adapter/converter what does the label said? Output? Input?
The inverter you have said 3.7A which is about 440W. I havn't see any laptop that need that much of power yet.
10A at 12V (120W) is different than 10A at 19V (190W), and so 10A at 120V (1200W).
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-22-2006, 04:26 PM   #12
good point...see, that's probably what's confusing me. the laptop is 56/72 watts regulated. Thanks. i see my error in thinking and i'll take it from here
THE GF THEME
Genesis has speed
Genesis has class
Genesis sent money
before your a__;)
What size inverter for 200w PC power supply? plus ATX shutdown question JiminyC Newbie 8 08-22-2005 11:43 PM
N00b Power Question jamiewhittingha Power Supplies 15 03-25-2005 12:08 AM
The Newbie with another power question nixneon Newbie 1 03-21-2005 11:05 AM
Noob question about power supplies Jagojon3 Newbie 10 03-08-2005 11:35 PM
Question about power and inverters and all that SBmp3 General Hardware Discussion 1 04-30-2003 11:35 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
