Old 02-17-2006, 12:15 PM   #1
TucsonPred's Avatar
TucsonPred is on a distinguished road
Is it possible.. (power options = sleep then off)
OK I've started thinking about my power options and what would be ideal for me, just wanted to see if others had tried it and had it work.
Parts: M2ATX + m10000+ laptop drive+ lilliput
What I'd like to so is put the machine into standby for an hour or so before it is shut down. This would be handy as a lot of the time I am just stopping for a couple minutes here and there. I'd like the ability for an almost instant on even if it is chewing up power for a short amount of time.
The plan:
Just use the M2ATX for all the power and timing (I currently have a ITPS+200V+DSSC for my timing switches)
Have the PC turn on from power loss
Set the power button to 'standby' (Providing standby will wake from the power button)
Standby for an hour or so
Set Windows XP to run like a laptop powering off after an hour or 2 (However this power off would be hibernate)
Is this possbile without having to hard reset randomly due to some odd power issue with the M2 or via?
2K SVT Lightning, Some things and the usual truck pc, now with slot load dvd rom and ECM Data logging.
05 Scion xA
TucsonPred is offline   Reply With Quote
Old 02-17-2006, 12:38 PM   #2
Raw Wave
justintime's Avatar
justintime is on a distinguished road
I'd like to do the same with my Opus150, but have no clue how to do it. I'll subscribe and see what others suggest...
2002 Honda CR-V
Spent so far: $1105.90
...or even Listen to my music
justintime is offline   Reply With Quote
Old 02-17-2006, 01:04 PM   #3
Psychobiker's Avatar
Psychobiker is on a distinguished road
Start - > Control Panel - > Power Options. Then there should be four boxxxes from which you can choose when it does what
L
1996 Volvo 850 T5 CD - Eventually I'll start....
Psychobiker is offline   Reply With Quote
Old 02-17-2006, 01:09 PM   #4
Tainted Love
Cris's Avatar
Cris is on a distinguished road
Is this really that simple...?
Cris is offline   Reply With Quote
Old 02-17-2006, 01:14 PM   #5
*Psychobiker thinks so* just installed PC in car, DAMN that inverter buzzes
Old 02-17-2006, 01:16 PM   #6
b8bboi is on a distinguished road
Doesn't hurt to try. This strategy works perfectly with all laptops. I'm not sure if it would work on a PC.
b8bboi is offline   Reply With Quote
Old 02-17-2006, 02:00 PM   #7
TucsonPred's Avatar
That's what my question is. Does it work and has anyone done it with a M2atx. My amp on will be run off it. I need the amp to turn off with the key off. I also am running an Audigy that 'pops' when it's unmuted from resume or on power up, I don't really want to have to used the DSSC still to triger the amp on.
The power options in Windows is pretty straight forward, but how the M@ would act is kind of up in the air. I'm also trying to figure out when the M2 gives the amp remote on. Is it right after post or 5 to 10 seconds later?
05 Scion xA
Old 02-17-2006, 02:12 PM   #8
DavC is on a distinguished road
While were on the subject, dows anyone know if it is somehow possible to set the "System Hibernates" for a period of longer than 6 hours?
I want to set mine up similar to this, but would be using an aux. battery.
DavC is offline   Reply With Quote
Old 02-18-2006, 04:25 PM   #9
bad-at-this is on a distinguished road
so I tried this and it didn't work...
I setup XP to sleep never and Hibernate after 20 minutes. Then the power button was set to sleep. So when the car turns off the M1 puts the computer to sleep (power button) and if I dont get back in the car in 20 minutes it "should" be hibernating right? But it is not. I was gone almost 2 hours (at which point it would have hard-offed from the m1) and it was still sleeping.
Any ideas?
-Bad
bad-at-this is offline   Reply With Quote
Old 02-18-2006, 04:49 PM   #10
Old 02-18-2006, 06:53 PM   #11
Tainted Love
Cris's Avatar
The idea is to have the pc go in standby when the ignition is off, and if the ignition is not triggered for let's say 2 hours, the pc goes into hibernation...that's the idea, but does it work?
Is this how you set it up Bad?
Old 02-18-2006, 10:33 PM   #12
muldrick's Avatar
muldrick is on a distinguished road
Maybe I'm not understanding the original question here, but why don't you guys just have the PSU cut power after 10 minutes (do a shuttdown, actually have the PC go into hybernate)
Then when you get back in the car, it'll boot quicker because it's coming out of hybernate.
I personally have my "remote-on" for my amp coming from my cruise control relay. So when I shut the car off, the amp turns off. When I start the car up, I let the pc come on, then hit my cruise control button which turns the amp on. (thereby avoiding the pop noise, because the pc is on before the amp is)
AtmosUSA.biz, E-Cig Mods
muldrick is offline   Reply With Quote
Old 02-18-2006, 10:44 PM   #13
Raw Wave
justintime's Avatar
I understand what bad-at-this wants (in fact, I want the exact same functiuonality), and I am susprised what he tried does not work, as this was going to be my suggestion after thinking about it a while.
Have not tried it myself, but it is disappointing that the hibernation does not kick in after the standby has been triggered by the PSU.
I really wish this was possible, because I tend to make several quick stops during a regular day, and the hibernate thing gets really boring.
2002 Honda CR-V
Old 02-18-2006, 10:45 PM   #14
Fusion Brain Creator
greenman100 is on a distinguished road
so you can only listen to music while cruise control is on?
greenman100 is offline   Reply With Quote
Old 02-18-2006, 10:47 PM   #15
Raw Wave
justintime's Avatar
HAHAHA! Don't be silly. His amp turns on with the SWITCH. Cruise Control can be off while the switch is ON. It's just a bypass in most cars, like Honda etc...
2002 Honda CR-V
psone power options jesse123 Newbie 33 12-06-2005 09:12 PM
Power Options Etno Newbie 17 04-22-2005 12:52 PM
I'm so confused about power options cfcrafting Power Supplies 14 04-14-2005 07:30 AM
Two power regulation options, which would you do? therussman2002 Power Supplies 9 01-11-2005 12:52 PM
FS For Sale 7" LCD VGA/USB, Opus 125w Power Supply, ATX P3-700 10GB 256r oudis Classified Archive 7 06-15-2004 10:29 PM
